How to install or enable the cdc_acm module
I need to use an Arduino MKRzero via USB with the Nano Pi S2. When run the command lsusb, the board appears:
Bus 001 Device 014: ID 2341:804f Arduino SA
however when I open the Arduino IDE the serial port is not listed. So I decided to run dmesg | grep Arduino -C 3
The output was:
[  591.600000] usb 1-1.6: new full-speed USB device number 10 using nxp-ehci
[  591.704000] usb 1-1.6: New USB device found, idVendor=2341, idProduct=804f
[  591.708000] usb 1-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  591.716000] usb 1-1.6: Product: Arduino MKRZero
[  591.720000] usb 1-1.6: Manufacturer: Arduino LLC
[  591.724000] usb 1-1.6: SerialNumber: 96EC4246514D3937394A2020FF101010
[  722.388000] usb 1-1.6: USB disconnect, device number 10
[  759.452000] usb 1-1.6: new full-speed USB device number 11 using nxp-ehci
And according to this site: http://chrisstrelioff.ws/sandbox/2015/12/08/arduino_on_ubuntu_14_04_without_the_arduino_ide.html
I supposed to get something like:
$ dmesg | grep Arduino -C 3
[ 6433.058276] usb 2-2: new full-speed USB device number 4 using xhci_hcd
[ 6433.077095] usb 2-2: New USB device found, idVendor=2341, idProduct=0043
[ 6433.077104] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[ 6433.077110] usb 2-2: Manufacturer: Arduino (www.arduino.cc)
[ 6433.077114] usb 2-2: SerialNumber: 75439333335351105031
[ 6433.077340] usb 2-2: ep 0x82 - rounding interval to 1024 microframes, ep desc says 2040 microframes
[b][ 6433.106521] cdc_acm 2-2:1.0: ttyACM0: USB ACM device[/b]
So I run the following command
root@NanoPi2:~# modprobe cdc_acm
modprobe: FATAL: Module cdc_acm not found.
root@NanoPi2:~# rmmod cdc_acm
rmmod: ERROR: Module cdc_acm is not currently loaded
So my question is how do I load that module or how can i solve de issue?
Thanks in advance
Sounds familiar to using a Teensy board on my old mini2440 system.
I think all that was required was
49-teensy-original.zip
(1.58 KiB) Downloaded 10998 times
Rename it 49-teensy.rules
This gets placed in /lib/udev/rules
It would need modifying. Are you sure there is not a suitable udev rule floating around somewhere?
Good luck!
Dave
Hello Dave,
Thanks a lot for your suggestions. However I'm no able to make it work.
I edit the rules with the following name: 98-mkrzero.rules and nothing happened.
ATTRS{idVendor}=="2341", ATTRS{idProduct}=="804f", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="2341", ATTRS{idProduct}=="804f", ENV{MTP_NO_PROBE}="1"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="2341", ATTRS{idProduct}=="804f", MODE:="0666"
KERNEL=="ttyAMA1", ATTRS{idVendor}=="2341", ATTRS{idProduct}=="804f", MODE:="0666"
I replace the ttyACM* for the ttyAMA* at the beginning, later to ttyAMA1 and when I opened the Arduino IDE the board was mapped to the ttyAMA1, so I was thinking that it worked. My bad, when I open the Arduino console, I was getting nothing, the board was programmed with a simple "Hello world!".
later checking at the /dev/ I noticed that the ttyAMA0 is the only one that is not in the dialup group but in the tty, and also with different access permissions.
I added my users to both groups and change the permissions and still not working.
I'm running out of ideas.
Looking again I see it goes in /lib/udev/rules.d not rules. You probably picked up that error.
I just fired up the old mini2440 with the Teensy 2 board and I get:
crw-rw-rw- 1 root dialout 166, 0 Jan 1 13:00 ttyACM0
and for the rules file:
-rw-r--r-- 1 root root 1982 Feb 28 2015 49-teensy.rules
I can't find or remember any other changes I had to make.
Are you sure there is no serial number?
ATTRS{serial}=="12345"
I ran two Teensy 2 boards and in the Teensy software I had to change the serial (number) so that I could talk specifically to one device.
Just realised that there was something else. There was a selection in my kernelconfig for serial USB which needed to be enabled and re-compiled.
Perhaps investigate whether or not you need to do that.
If you ever found a fix for this it would be very helpful to share it. I've tried recompiling the kernel with it and still running into a wall.
I'm also in need of the cdc-acm driver. This is often enabled by default for linux kernels.
