NanoPi NEO2-LTS Clock Speed
I just assembled my NEO2 Metal Complete Kit. Everything went great, but for my application, DietPi is a better fit, so I immediately re-flashed the microSD card with Stretch. When I login, DietPi says that the CPU is limited to maximum clock speed of 1,008 MHz. I was expecting to see 1.5 Ghz. Is this correct?
Otherwise, everything that I need is working perfectly. The device runs very cool (in the mid 30ºC range) in the provided aluminum case. I don't have the display working in DietPi, but I don't really need it for my application.
Please let me know if the CPU speed that I'm seeing is expected. Thanks.
-- David
Board revision 1.1 can go up to 1.3Ghz but Dietpi folks have no clue about that:
https://forum.armbian.com/topic/9797-na ... ment=73964
In total there are 5 users online :: 0 registered, 0 hidden and 5 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 5 guests
