copy protection NanoPC-T3
Posted: Sun Sep 04, 2016 10:44 am
Hi All!
By accident I found your really interesting product, maybe you can improve the google ranking somehow
Usually all ARM boards make use of SD Cards to store the image and software, which is conisderably easy to copy/clone. I am aware that everything is breakable nevertheless I wonder if T3 makes this more difficult by storing the entire software in the 8GB emmc and not SD? Is it possible to disable the debugging interface and is it possible to prevent that the emmc content is exposed to the outside world (read out prevention)? Basically I wonder if there is an ARM based board which allows usage beyond dev / learning / hobby and bringing it to the "wild" as a product?
Do you provide a minimal Debian(?) headless image with WiFi, ethernet and flash (for example HDMI is not requirred)?
Thanks in advance
Jens
Thanks in advance
Jens
