Realtek driver fails to build
Posted: Thu Jan 16, 2020 8:09 am
I am working with Android 7 for the NanoPC T3 Plus and I can build it without error using custom u-boot and custom kernel.
I need to enable the Realtek WiFi drivers and if I change the following line in wifi_bt_config.mk from:
to:
And then try to build Android, I get an error because it can't find wlan.ko reference in the device.mk file
Has anyone else been able to build the source with Realtek drivers enabled? Where did you get the wlan.ko file from?
It looks like I need to build the actual kernel source to create the wlan.ko file but there is nothing in the kernel to do this.
BOARD_WIFI_VENDOR := broadcomto:
BOARD_WIFI_VENDOR := realtek
ifeq ($(BOARD_WIFI_VENDOR),realtek)
PRODUCT_PACKAGES += \
rtw_fwloader
PRODUCT_COPY_FILES += \
hardware/realtek/wlan/driver/rtl8188eus/wlan.ko:system/vendor/realtek/wlan.ko
endifHas anyone else been able to build the source with Realtek drivers enabled? Where did you get the wlan.ko file from?
