Different CPU temp for power from microUSB or headers PINs
we are experiencing a strange issue:
- if the NanoPi NEO board is powered by microUSB the temperature of the board stays around 70C
- if we connect the same power supply to the header pins, the temperature of the board goes up to 90C
Attached is a RRD graph we create reading the board temp from /sys/devices/virtual/thermal/thermal_zone0/temp
Any idea why ?
I would also like to know the reason behind this different temperature readings on two different methods of powering the nanopi.
bump
In total there are 29 users online :: 0 registered, 0 hidden and 29 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 29 guests
