Turn off / on USB (incl. power) via command line on NPi Neo
Is it possible to turn the USB off and on (incl. power) via the command line on a Nano Pi Neo?
Grab the schematic for your specific Nano and trace the 5V switching circuit output to your USB connector. The units I have worked on have the USB supply directly connected to the 5V switch-over circuit.
So, with a hardware mod you might be able to switch the USB 5V supply line on and off.
I have never seen a command to turn USB functionality on and off, but maybe there is.
In total there are 31 users online :: 0 registered, 0 hidden and 31 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 31 guests
