NanoPi Air + CAM500B, VE Open Error
Posted: Mon Jul 16, 2018 8:01 am
I'm using nanopi-neo-air_FriendlyCore-Xenial_3.4.39_20171102.img as is, without any apt-get update or upgrade, meaning
- drivers are provided by friendlycore.
- ffmpeg is the friendlycore customized version.
I followed the wiki page and run the following command
But I got error
I'm not sure how VE is supported, as my lsmod returned the following.
How should I get CAM500B working?
ffmpeg -t 30 -f v4l2 -channel 0 -video_size 1280x720 -i /dev/video0 -pix_fmt nv12 -r 30 \
-b:v 64k -c:v cedrus264 test.mp4But I got error
pi@NanoPi-NEO-Air:~$ ffmpeg -t 30 -f v4l2 -channel 0 -video_size 1280x720 -i /dev/video0 -pix_fmt nv12 -r 30 \
ffmpeg version 2.3.git Copyright (c) 2000-2014 the FFmpeg developers
built on Sep 6 2016 11:47:46 with gcc 5.2.1 (Ubuntu 5.2.1-22ubuntu2) 20151010
configuration: --prefix=/usr --enable-nonfree --enable-gpl --enable-version3 --enable-vdpau --enable-libx264 --enable-libmp3lame --enable-libpulse --enable-libv4l2
libavutil 54. 6.100 / 54. 6.100
libavcodec 56. 0.101 / 56. 0.101
libavformat 56. 2.100 / 56. 2.100
libavdevice 56. 0.100 / 56. 0.100
libavfilter 5. 0.102 / 5. 0.102
libswscale 3. 0.100 / 3. 0.100
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 0.100 / 53. 0.100
Input #0, video4linux2,v4l2, from '/dev/video0':
Duration: N/A, start: 1531727714.421512, bitrate: 331776 kb/s
Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 1280x720, 331776 kb/s, 30 fps, 30 tbr, 1000k tbn, 1000k tbc
[cedrus264 @ 0xf5a560] VE Open error.
Output #0, mp4, to 'test.mp4':
Stream #0:0: Video: h264, q=2-31, 128 kb/s, 30 fps
Metadata:
encoder : Lavc56.0.101 cedrus264
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (cedrus264))
Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or heightI'm not sure how VE is supported, as my lsmod returned the following.
pi@NanoPi-NEO-Air:~$ lsmod
Module Size Used by
cdc_ether 3006 0
usbnet 13246 1 cdc_ether
bcmdhd 599208 0
cfg80211 470289 1 bcmdhd
compat 25372 2 cfg80211,bcmdhdHow should I get CAM500B working?
