[NanoPi Neo Core] ubuntu build can't do broadcast to outside
Posted: Mon Jan 13, 2020 1:46 am
Recently, I got a piece of hardware, NonoPi Neo Core. I use ubuntu to install gcc and upload a broadcasting sample code and try to do broadcast to same network class. Here is my network topology.
D-Link Router(A) 192.168.1.1 (255.255.255.0)
||=== NonoPi NeoCore(B) 192.168.1.161 (255.255.255.0) client.c installed
||=== Virtualbox (ubuntu16.04 (C)) 192.168.1.20 (255.255.255.0) client.c installed
||=== PC install ubuntu16.04(D) 192.168.1.21 (255.255.255.0) server.c, client.c installed
||=== PC install windows10(E) 192.168.1.12 (255.255.255.0) wireshark installed
B,C,D,E are in same network. I upload a broadcasting program client.c file to those computers and also compile that.
here is the client testing program location.
https://forums.freebsd.org/threads/socket-programming-in-c-language-unable-to-broadcast-a-message-from-freebsd-client-to-linux-server-broadcast-ip-should-be-255-255-255-255.67722/
I did not use this server.c program, instead, my Server program on PC(D), join broadcast group, is listening to 239.143.143.143:4950. Also wireshark filter on PC(E) listening to the same address. { ip.addr=192.168.1.161 && udp }
Strange thing happened. I use this client.c program inside C, D host, it works as expected, my server program can receive broadcast message, wireshark also got broadcast message. Inside (B) NeoCore, the screen also shows "sent 10 bytes to 239.143.143.143", but wireshark in (E) does not see anything. Server program on PC(D) does not see anything also. Weird thing is that, exchange position from server.c and client.c, you can see my server.c on NeoCore(B) received broadcast message from (C), (D) client.c, wireshark on (E) also receive.
I start to check routing table on B, everything is fine, nothing wield.
I open tcpdump on NeoCore(B), I can see client.c program tried to send out broadcast message, but was dropped. WHY ??
Can anyone help me here? please post your idea or solution here or contact me directly.
many thanks ~
-neo
root@NanoPi-NEO-Core:/home/neo# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 eth0
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
That means NonoPi Neo Core ubuntu 16.04 cannot do bi-direction broadcast, but in a nornal PC version ubuntu 16.04, it does bi-direction broadcast. What happen to NEO CORE ??Can anyone help me here? please post your idea or solution here or contact me directly.
iamneo2416@gmail.commany thanks ~
-neo
