NanoPi NEO Air, USB issues
Posted: Sat Oct 15, 2016 3:06 pm
I cut a USB cable to about 3", and soldered the following.
Red wire to pin 1
White Wire to pin 2
Green wire to pin 3
Black wire to pin 12
I have plugged in several different kinds of USB devices from pen drives, Ethernet adapters, audio devices and none of them enumerate. I have used these same devices on your other products with no issues at all.
here is the result on the terminal when I plug one of them in.
[ 123.090138] usb 7-1: device descriptor read/64, error -62
[ 123.380119] usb 7-1: device descriptor read/64, error -62
[ 123.850255] usb 7-1: device descriptor read/64, error -62
[ 124.140157] usb 7-1: device descriptor read/64, error -62
[ 124.850113] usb 7-1: device not accepting address 8, error -62
[ 125.450112] usb 7-1: device not accepting address 9, error -62
[ 125.456665] hub 7-0:1.0: unable to enumerate USB device on port 1
I even tried moving the white & green wires to USB2 but had the same results.
Red wire to pin 1
White Wire to pin 2
Green wire to pin 3
