Problems blinking an LED with NanoPi NEO
Posted: Mon Feb 27, 2017 7:50 pm
Hello
I am working with a NanoPi NEO and am trying to flash an LED. I have it connected to pin 23 of the 24-pin connector (through a series resistor), which I believe is GPIOC2. I am using the Bakebit software (Python) and have changed the pin number to '66' in the Python script
My led is not blinking. I have tried different port numbers and different pins. I have measured voltage on all pins in the 24-pin connector while the blink script was running to try to find the correct pin but found no luck. I don't have the BakeBit board - could this be the problem? Oddly enough, I did manage to get an OLED display to work using pins 3 and 5 (SDA/SCL).
Any suggestions on what to try next?
thx
led = 66My led is not blinking. I have tried different port numbers and different pins. I have measured voltage on all pins in the 24-pin connector while the blink script was running to try to find the correct pin but found no luck. I don't have the BakeBit board - could this be the problem? Oddly enough, I did manage to get an OLED display to work using pins 3 and 5 (SDA/SCL).
thx
