Using GPIOs via command line
This is just to help people out. Initially, you have to be root to be able to use the GPIO pins via the command line. So, to get beyond having to be root, here are some tips.
sudo groupadd gpio
sudo usermod -aG gpio user-name
and, then (add these lines to the 99-gpio.rules file):
sudo nano /etc/udev/rules.d/99-gpio.rules
SUBSYSTEM=="gpio", KERNEL=="gpiochip*", ACTION=="add", PROGRAM="/bin/sh -c 'chown root:gpio /sys/class/gpio/export /sys/class/gpio/unexport ; chmod 220 /sys/class/gpio/export /sys/class/gpio/unexport'"
SUBSYSTEM=="gpio", KERNEL=="gpio*", ACTION=="add", PROGRAM="/bin/sh -c 'chown root:gpio /sys%p/active_low /sys%p/direction /sys%p/edge /sys%p/value ; chmod 660 /sys%p/active_low /sys%p/direction /sys%p/edge /sys%p/value'"
Save and reboot. Now, you should be able to do things like (turn an LED on and off on pin 8):
echo 8 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio8/direction
echo 1 > /sys/class/gpio/gpio8/value
echo 0 > /sys/class/gpio/gpio8/value
echo 8 > /sys/class/gpio/unexport
You could also use WiringNP for the GPIOs - according to the NanoPi Duo Wiki:
http://wiki.friendlyarm.com/wiki/index.php/NanoPi_Duo#Access_GPIO_Pins.2FWirings_with_WiringNP
Make a shell script:
vi test.sh
Type the following lines:
LED=8
gpio mode $LED out
while true; do
  gpio write $LED 1
  sleep 0.5
  gpio write $LED 0
  sleep 0.5
done
Run the script:
sudo source test.sh
You can see the LED is blinking.
The wiringPi library was initially developed by Gordon Henderson in C.
It contains libraries to access GPIO, I2C, SPI, UART, PWM and etc.
The wiringPi library contains various libraries, header files and a commandline utility:gpio.
The gpio utility can be used to read and write GPIO pins.
FriendlyElec integrated this utility in Duo's system allowing users to easily access GPIO pins.
For more details refer to WiringNP
http://wiki.friendlyarm.com/wiki/index.php/WiringNP:_NanoPi_NEO/NEO2/Air_GPIO_Programming_with_C#Shell_Script
