Booting via SATA
Installed a m.2 sata adapter in the dev unit and linux sees it so I know the os supports the card.
Trying to find any info on how to get unit to boot directly off sata. Found other boards have a spi flash with petitboot on them to support this. Does this board have a way to support this feature.
We are looking to do this because were installing a raidon sata unit that we would like for redundancy.
Trying to find any info on how to get unit to boot directly off sata. Found other boards have a spi flash with petitboot on them to support this. Does this board have a way to support this feature.tomb of the mask
You need to check the bootloader or firmware settings on the motherboard, as they may support booting from SATA. :D
