main stream buildroot for nanopi m4v2
Has anyone tried to build the nanopi m4v2 with main stream buildroot? I used the nanopi_m4_defconfig in buildroot. But the image is for nanopi m4.
output from serial console:
U-Boot TPL 2020.07 (Feb 16 2021 - 22:53:03)
sdram_init: LPDDR3 - 933MHz failed!
rk3399_dmc_init DRAM init failed -22
Missing DTB
Is there a way to build a image works with nanopi m4v2? Is there a m4v2 configuration I can use with main stream buildroot?
You can look at this solution,
viewtopic.php?f=61&t=3619&p=10366&hilit=buildroot#p10366
Should be enough to get going.
In total there are 22 users online :: 0 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 22 guests
