Overclock and cpu selection
Is there any way to overclock nanopc T4 and can we select which cpu group will be used ?
Armbian comes overclocked OOB. You can go a little more, but you need damn good cooling and you risk failures.
Default overclock:
https://github.com/armbian/build/blob/m ... -2.0.patch
Optional - require DT recompile:
https://github.com/armbian/build/blob/m ... h.disabled
+ manipulating temperature throtling points
https://github.com/armbian/build/blob/m ... ture.patch
In total there are 27 users online :: 0 registered, 0 hidden and 27 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 27 guests
