NanoPi M4 - Wifi - Can only see one 5Ghz network
Hey there !
I just bought a NanoPi M4, and it looks awesome ; sadly, I have an issue.
The networks list can only see one network around me, luckily it's mine, the 5Ghz one, but litteraly NO OTHER network.
And even when connected to the 5Ghz network, with the router 5 meters in the same room, the connexion is very poor and often disconnect.
iw phy list all the proper frequencies (2.4, ...) but the networks list can't seem to pick any up.
Does anybody have an idea ?
Did you solved the issue?
I would recommend to check the antenna connectors first.
In total there are 33 users online :: 1 registered, 0 hidden and 32 guests (based on users active over the past 5 minutes)
Users browsing this forum: Baidu [Spider] and 32 guests
