All cores are recognized as little core
Posted: Sat Sep 21, 2019 1:59 pm
I'm using Nanopi M4 installed Armbian Buster.
It works like charm but I found a strange behavior of the system.
In htop all cores are displayed as little core. but when I checked actual clocks in /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_cur_freq big cores are doing well (up to 1.8GHz).
this is my lscpu result:
Is this result normal?
Architecture: aarch64
Byte Order: Little Endian
CPU(s): 6
On-line CPU(s) list: 0-5
Thread(s) per core: 1
Core(s) per socket: 3
Socket(s): 2
Vendor ID: ARM
Model: 4
Model name: Cortex-A53
Stepping: r0p4
CPU max MHz: 1800.0000
CPU min MHz: 408.0000
BogoMIPS: 48.00
Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32Is this result normal?
