Power NanoPC-T4 from battery
Hello all.
In the specifications, the power input is 12V/2A but I can not find if there is an acceptable voltage range. is it possible to power the board from a 3S Li-Ion battery (9 - 12.6V)?
Thank you and best regards.
I wonder if the manufacturer has specified an acceptable voltage range for this board? Because if it only says 12V/2A, is it safe to use a 3S battery ranging from 9V to 12.6V for the board?
In total there are 49 users online :: 0 registered, 0 hidden and 49 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 49 guests
