That has an 8 bit SSD1963 so you'd need a driver and enough GPIO to use it.
From what I can see, the Neo Air is a headless design only. There is no interface for video that would be plug-in. You might be able to get a small form factor SPI interfaced LCD to work but you'll need to find drivers etc.
FA do have this display but screen size is much smaller.
I had a similar project, thanks for your answer! I'll get a smaller display instead, and if it works (or doesn't), I'll describe my build on the forum.
In total there are 11 users online :: 0 registered, 0 hidden and 11 guests (based on users active over the past 5 minutes) Most users ever online was 5265 on Sun Aug 31, 2025 11:40 pm
