NanoPI M4 - does not recognize 4K monitors - limited to 1920
Posted: Tue Jan 01, 2019 3:36 pm
super happy with M4 sofar. Easy install from SD to MMC, it is fast with Friendlyarm Desktop 18.04 dec 19, 2018 release.
but
HDMI output defaults to 1920x1080@60. Works fine for most scenario's but i want feed some big 4K screens on the wall with NanoPI. Tested with LG 27UD68P en IiyamaPL2792UH both support 3840x2160.
xrandr gives
dmesg | grep -Ei "(drm)|(edid)" gives
@chensy let me know if you need anything else to debug
greetings William
but
xrandr gives
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
eDP-1 disconnected primary (normal left inverted right x axis y axis)
HDMI-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 600mm x 340mm
1920x1080 60.00* 59.94 30.00 29.97
1920x1080i 60.00 59.94
1600x900 60.00
1280x1024 60.02
1280x800 59.91
1152x864 59.97
1280x720 60.00 59.94
1024x768 60.00
800x600 60.32
720x480 60.00 59.94
640x480 60.00 59.94
DP-1 disconnected (normal left inverted right x axis y axis)
[ 1.066491] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 1.071026] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 1.095922] [drm] Initialized drm 1.1.0 20060810
[ 1.099771] [drm] Rockchip DRM driver version: v1.0.1
[ 1.665254] rockchip-drm display-subsystem: defer getting devfreq
[ 1.667354] [drm] no mcu-timing node found in /vop@ff900000
[ 1.667872] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008cf31b8)
[ 1.669547] [drm] no mcu-timing node found in /vop@ff8f0000
[ 1.670059] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008cf31b8)
[ 1.673867] rockchip-drm display-subsystem: bound ff970000.edp (ops 0xffffff8008cea738)
[ 1.677982] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008ce80a8)
[ 1.681797] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008ce9060)
[ 1.682523] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.683111] [drm] No driver support for vblank timestamp query.
[ 1.721115] rockchip-drm display-subsystem: can't not find any loader display
[ 1.721774] rockchip-drm display-subsystem: failed to show loader logo
[ 1.722707] Freeing drm_logo memory: 2252K
[ 1.763123] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 14
[ 1.763705] rockchip-vop ff8f0000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[ 2.053336] rockchip-drm display-subsystem: fb0: frame buffer device
[ 4.701131] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 6.820147] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[ 7.939483] [drm] unsupported connector property: hdmi_color_depth_capacity@chensy let me know if you need anything else to debug
greetings William
