DPKG Frontend Lock Error
E: Could not get lock /var/lib/dpkg/lock-frontend - open (11: Resource temporarily unavailable)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
I am getting this error while installing opencv on PI M4. I have a Friendly Core and I am following the Wiki Steps given.
Any ideas on solution ?
you probably have unattended-upgrades installed. To verify :
systemctl cat unattended-upgrades.service
If so, then you just have to wait until this process have finish its current upgrade ;)
If you try to make install ewerything, try to do so:
for example:
sudo apt-get install gnome-disk-utility:arm64
Thanks..
rvalvekar wrote:
Thanks..
got this also on some new installations of armbian ;)
try
ps -ef|grep apt
If there is only the task of this command for apt then you could apt again - if there is more you should wait to let the installation be completed.
