Hello all,
I'm currently building android 10 using the git source available from the wiki for the T4. Everything is successful, and I have fully built the image and deployed it. Now I am trying to go back to the code and add in root plus some other modules. No worries with everything until I get to the root portion. I'm using supersu 2.82 (the same code and method from the last version of android for the rk3399). Everything compiles until it gets to 100% and runs a few last commands. Then it errors out with an overwrite issue. Here is the code.
Any ideas? Any leads I could look into with the advice of someone who's been here before? Thanks you guys.
[100% 12699/12699] writing build rules ...
FAILED:
build/make/core/Makefile:28: error: overriding commands for target `out/target/product/nanopc-t4/system/xbin/su', previously defined at build/make/core/base_rules.mk:480
20:44:59 ckati failed with: exit status 1Any ideas? Any leads I could look into with the advice of someone who's been here before? Thanks you guys.
