I was running openwrt snapshot on r2c plus, but I ended up preferring to go back to friendlywrt, using the rk3328-usb-friendlywrt-23.05-20240329 image on emmc via usb.
During the process, I received the "Test device Fail" error. When trying to boot again, using emmc, openwrt was no longer working.
I saved the image rk3328-eflasher-friendlywrt-22.03-20230524 on an sdcard and when connecting the r2c, it booted to the card without needing to connect the maskrom, but it did not record the image on the emmc.
When running eflasher manually I got the message
After the error, I wrote the image rk3328-sd-friendlycore-focal-4.19-arm64-20240131 to the sdcard, it booted normally, but I couldn't locate the emmc and the network interfaces aren't working either.
I would be grateful if anyone could help me.
15:58:08 464 瑞芯微开发工具 v2.7.1.0 start run
15:58:33 420 瑞芯微开发工具 v2.7.1.0 start run
15:58:54 424 RKDevTool v2.7.1.0 start run
16:00:51 530 Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0
16:00:53 547 INFO:RKU_ResetPipe-->DeviceIoControl OK
16:00:58 590 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
16:00:58 590 Error:ReadFlashIDProc-->RKU_ReadFlashInfo failed,err=-3
16:01:01 805 Layer<2-1-4>:Download Boot Start
16:01:05 081 Layer<2-1-4>:Download Boot Success
16:01:05 081 Layer<2-1-4>:Wait For Maskrom Start
16:01:06 698 Layer<2-1-4>:Wait For Maskrom Success
16:01:06 698 Layer<2-1-4>:Test Device Start
16:01:11 115 Error:RKU_Write-->WriteFile failed,bRet=0,err=995,size=31,write=0
16:01:13 136 ERROR:RKU_ResetPipe-->CreateFile \\?\USB#VID_2207&PID_320C#6&3B52181F&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} failed,err=2
16:01:13 136 <LAYER 2-1-4> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-3),path=\\?\USB#VID_2207&PID_320C#6&3B52181F&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
16:01:14 166 Error:RKU_Open-->CreateFile failed,err=3,path=\\?\USB#VID_2207&PID_320C#6&3B52181F&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
16:01:14 166 <LAYER 2-1-4> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-1),path=\\?\USB#VID_2207&PID_320C#6&3B52181F&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
16:01:15 211 Error:RKU_Open-->CreateFile failed,err=3,path=\\?\USB#VID_2207&PID_320C#6&3B52181F&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
16:01:15 211 <LAYER 2-1-4> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-1),path=\\?\USB#VID_2207&PID_320C#6&3B52181F&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
16:01:16 256 Error:Layer<2-1-4>:Test Device Fail
16:01:16 276 Layer<2-1-4>: RunProc is ending, ret=0
16:02:44 908 Layer<2-1-4>:Download Boot Start
16:02:44 972 <LAYER 2-1-4> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(28674),Sended(0),bRet(0),err(1f)
16:02:44 972 <LAYER 2-1-4> ERROR:DownloadBoot-->Boot_VendorRequest471 failed,index(0)
16:02:44 988 Error:Layer<2-1-4>:Download Boot Fail
16:02:45 025 Layer<2-1-4>: RunProc is ending, ret=0I saved the image rk3328-eflasher-friendlywrt-22.03-20230524 on an sdcard and when connecting the r2c, it booted to the card without needing to connect the maskrom, but it did not record the image on the emmc.
Using config file: "/mnt/sdcard/eflasher.conf"
open file error: "/sys/class/block/mmcblk2/device/name"
No eMMC detected, , ,After the error, I wrote the image rk3328-sd-friendlycore-focal-4.19-arm64-20240131 to the sdcard, it booted normally, but I couldn't locate the emmc and the network interfaces aren't working either.
DDR version 1.16 20190528
In
DDR4
333MHz
Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
ddrconfig:14
OUT
Boot1 Release Time: May 13 2019 17:34:36, version: 2.50
ChipType = 0x11, 248
emmc reinit
emmc reinit
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
FwPartOffset=2000 , 0
run on sd0
StorageInit ok = 6992514
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
atags_set_bootdev: ret:(0)
GPT part: 0, name: uboot, start:0x4000, size:0x2000
GPT part: 1, name: trust, start:0x6000, size:0x2000
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: dtbo, start:0xa000, size:0x2000
GPT part: 4, name: resource, start:0xc000, size:0x8000
GPT part: 5, name: kernel, start:0x14000, size:0x14000
GPT part: 6, name: boot, start:0x28000, size:0x18000
GPT part: 7, name: rootfs, start:0x40000, size:0x5c0000
GPT part: 8, name: userdata, start:0x600000, size:0x887525
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xeabf8
RunBL31 0x40000
NOTICE: BL31: v1.3(release):734d842
NOTICE: BL31: Built : 15:29:53, Dec 26 2019
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
INFO: BL31: Initializing runtime services
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-235-g3b0152ca #231 Fri Mar 13 02:01:39 UTC 2020 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.4
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-g43267f9286-200623 #root (Jul 07 2021 - 16:49:31 +0800)
Board: FriendlyELEC RK3328 board
PreSerial: 2
DRAM: 992 MiB
Sysmem: init
Relocation Offset: 3dbd8000, fdt: 3bdcd838
Using default environment
no mmc device at slot 1
Found IDB in SDcard
mmc@ff500000: 1 (SD), mmc@ff520000: 0
Bootdev(atags): mmc 1
MMC1: Legacy, 50Mhz
PartType: EFI
boot mode: None
Found DTB in resource part
DTB: rk3328-nanopi-r2-rev22.dtb (77863)
HASH(c): OK
ANDROID: fdt overlay OK
I2c1 speed: 100000Hz
PMIC: RK8050 (on=0x40, off=0x00)
vdd_logic init 1000000 uV
vdd_arm init 1225000 uV
I2c0 speed: 100000Hz
Rockchip UBOOT DRM driver version: v1.0.1
CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 0N/A)
apll 400000 KHz
dpll 664000 KHz
cpll 1200000 KHz
gpll 491009 KHz
npll 600000 KHz
armclk 600000 KHz
aclk_bus 150000 KHz
hclk_bus 75000 KHz
pclk_bus 75000 KHz
aclk_peri 150000 KHz
hclk_peri 75000 KHz
pclk_peri 75000 KHz
Net: eth0: ethernet@ff540000
Hit key to stop autoboot('CTRL+C'): 1 0
## Booting Rockchip Format Image
fdt @ 0x08300000 (0x000131b7)
kernel @ 0x00280000 (0x01bad808)
ramdisk @ 0x0a200000 (0x007b2bc0)
Fdt Ramdisk skip relocation
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
Using Device Tree in place at 0000000008300000, end 00000000083161b6
Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x0a200000 - 0x40000000 (size: 0x35e00000)
Total: 3733.105 ms
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.19.232 (ubuntu@c5373b57c425) (gcc version 11.3.0 (ctng-1.25.0-119g-FA), GNU ld (GNU Binutils) 2.38) #1 SMP Fri Dec 8 15:54:52 CST 2023
[ 0.000000] Machine model: FriendlyElec NanoPi R2C Plus
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000ff130000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] cma: Reserved 16 MiB at 0x000000003f000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 24 pages/cpu s59496 r8192 d30616 u98304
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 249864
[ 0.000000] Kernel command line: storagemedia=sd androidboot.storagemedia=sd androidboot.mode=normal androidboot.dtbo_idx=1 earlycon=uart8250,mmio32,0xff130000 console=ttyFIQ0 swiotlb=1 coherent_pool=1m rw root=/dev/mmcblk0p8 rootfstype=ext4 data=/dev/mmcblk0p9 consoleblank=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 940136K/1015808K available (14718K kernel code, 2230K rwdata, 4524K rodata, 6848K init, 906K bss, 59288K reserved, 16384K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 46857 entries in 184 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x4ec with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.001916] Console: colour dummy device 80x25
[ 0.002411] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003383] pid_max: default: 32768 minimum: 301
[ 0.004070] Security Framework initialized
[ 0.004472] AppArmor: AppArmor disabled by boot time parameter
[ 0.005121] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.005797] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.008938] ASID allocator initialised with 32768 entries
[ 0.009700] rcu: Hierarchical SRCU implementation.
[ 0.015157] smp: Bringing up secondary CPUs ...
[ 0.016494] Detected VIPT I-cache on CPU1
[ 0.016580] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.017594] Detected VIPT I-cache on CPU2
[ 0.017666] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.018575] Detected VIPT I-cache on CPU3
[ 0.018641] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.018789] smp: Brought up 1 node, 4 CPUs
[ 0.022224] SMP: Total of 4 processors activated.
[ 0.022678] CPU features: detected: 32-bit EL0 Support
[ 0.029315] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.030133] CPU: All CPU(s) started at EL2
[ 0.030601] alternatives: patching kernel code
[ 0.032916] devtmpfs: initialized
[ 0.058551] Registered cp15_barrier emulation handler
[ 0.058577] Trying to unpack rootfs image as initramfs...
[ 0.059078] Registered setend emulation handler
[ 0.059583] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.059603] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.062802] pinctrl core: initialized pinctrl subsystem
[ 0.065178] NET: Registered protocol family 16
[ 0.066993] schedtune: configured to support 6 boost groups
[ 0.067822] audit: initializing netlink subsys (disabled)
[ 0.068715] audit: type=2000 audit(0.066:1): state=initialized audit_enabled=0 res=1
[ 0.071383] cpuidle: using governor menu
[ 0.071849] Registered FIQ tty driver
[ 0.072742] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.076246] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.107349] rockchip-gpio ff210000.gpio0: probed gpio0 (ff210000.gpio0)
[ 0.109046] rockchip-gpio ff220000.gpio1: probed gpio1 (ff220000.gpio1)
[ 0.110774] rockchip-gpio ff230000.gpio2: probed gpio2 (ff230000.gpio2)
[ 0.112434] rockchip-gpio ff240000.gpio3: probed gpio3 (ff240000.gpio3)
[ 0.113241] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.133515] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.134754] cryptd: max_cpu_qlen set to 1000
[ 0.137572] fiq debugger fiq mode enabled
[[ 0.138591] console [ttyFIQ0] enabled
[ 0.139281] bootconsole [uart8250] disabled
[ 0.140033] Registered fiq debugger ttyFIQ0
[ 0.142714] reg-fixed-voltage sdmmc-regulator: Failed to register regulator: -517
[ 0.144624] gpio-regulator sdmmcio-regulator: Failed to register regulator: -517
[ 0.145153] rk_iommu ff330200.iommu: version = 1
[ 0.145889] rk_iommu ff340800.iommu: version = 1
[ 0.146462] rk_iommu ff350800.iommu: version = 1
[ 0.146962] rk_iommu ff360480.iommu: version = 1
[ 0.147400] rk_iommu ff373f00.iommu: version = 1
[ 0.147881] rk_iommu ff3a0800.iommu: version = 1
[ 0.149104] SCSI subsystem initialized
[ 0.149540] usbcore: registered new interface driver usbfs
[ 0.149615] usbcore: registered new interface driver hub
[ 0.149694] usbcore: registered new device driver usb
[ 0.150138] media: Linux media interface: v0.10
[ 0.150196] videodev: Linux video capture interface: v2.00
[ 0.150356] pps_core: LinuxPPS API ver. 1 registered
[ 0.150367] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.150398] PTP clock support registered
[ 0.153541] Advanced Linux Sound Architecture Driver Initialized.
[ 0.154508] Bluetooth: Core ver 2.22
[ 0.154605] NET: Registered protocol family 31
[ 0.154616] Bluetooth: HCI device and connection manager initialized
[ 0.154640] Bluetooth: HCI socket layer initialized
[ 0.154657] Bluetooth: L2CAP socket layer initialized
[ 0.154713] SCO socket layer initialized
[ 0.154753] NetLabel: InitializNetLabel: domain hash size = 128
[ 0.154777] NetLabel: proPSOv4 CALIPSO
[ 0.154897] NetLabel: unlabeled traffic allow0.155700] rockchip-cpuinfo cpuinfo: SoC: 1000
[ 0.155727] fo: Serial: e87d76cdd98195e0
[ 0.157622] clocksource: Switarch_sys_counter
[ 0.266587] VFS: Disk quotas dquot_6.6.0
[ 0.266748] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.266949] FS-Cache: Loaded
[ 0.281631] NET: Registered protocol family 2
[ 0.281897] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.283574] tcp_listen_portaddr_hash hash table entries: 512 (order: 2, 20480 bytes)
[ 0.283668] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.283791] TCP bind hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.284188] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.284610] UDP hash table entries: 512 (order: 3, 49152 bytes)
[ 0.284710] UDP-Lite hash table entries: 512 (order: 3, 49152 bytes)
[ 0.285105] NET: Registered protocol family 1
[ 0.285987] RPC: Registered named UNIX socket transport module.
[ 0.286015] RPC: Registered udp transport module.
[ 0.286028] RPC: Registered tcp transport module.
[ 0.286040] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.289321] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.292672] Initialise system trusted keyrings
[ 0.293139] workingset: timestamp_bits=45 max_order=18 bucket_order=0
[ 0.308389] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.309217] Registering sdcardfs 0.1
[ 0.309777] FS-Cache: Netfs 'nfs' registered for caching
[ 0.310881] NFS: Registering the id_resolver key type
[ 0.311021] Key type id_resolver registered
[ 0.311035] Key type id_legacy registered
[ 0.311068] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.311099] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.311507] fuse init (API version 7.27)
[ 0.312781]
[ 0.312781] TEE Core Framework initialization (ver 1:0.1)
[ 0.312839] TEE armv7 Driver initialization
[ 0.313479] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[ 0.313501] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[ 0.313870] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=63)
[ 0.316582] Key type asymmetric registered
[ 0.316608] Asymmetric key parser 'x509' registered
[ 0.316708] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.317063] io scheduler noop registered
[ 0.317571] io scheduler cfq registered (default)
[ 0.317647] io scheduler mq-deadline registered
[ 0.317662] io scheduler kyber registered
[ 0.317886] io scheduler bfq registered
[ 0.324039] phy phy-ff450000.syscon:usb2-phy@100.1: Linked as a consumer to regulator.2
[ 0.328048] rockchip-u3phy ff470000.usb3-phy: Linked as a consumer to regulator.1
[ 0.330742] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully
[ 0.333938] rockchip-pwm ff1b0020.pwm: No active pinctrl state
[ 0.335842] iommu: Adding device ff3a0000.iep to group 5
[ 0.335942] iep ff3a0000.iep: Linked as a consumer to ff3a0800.iommu
[ 0.336194] iep: failed to find iep power down clock source.
[ 0.337026] iep: IEP Power ON
[ 0.337120] iep: IEP Power OFF
[ 0.337161] iep: IEP Driver loaded succesfully
[ 0.337528] iep: Module initialized.
[ 0.337838] mpp_service mpp-srv: 09401c57307d author: Yandong Lin 2023-08-04 video: rockchip: mpp: fix irq on poweroff for rkvdec2_link
[ 0.337855] mpp_service mpp-srv: probe start
[ 0.339331] iommu: Adding device ff360000.rkvdec to group 3
[ 0.339391] mpp_rkvdec ff360000.rkvdec: Linked as a consumer to ff360480.iommu
[ 0.339659] mpp_rkvdec ff360000.rkvdec: probing start
[ 0.340184] rkvdec_init:1226: failed on clk_get clk_hevc_cabac
[ 0.340294] mpp_rkvdec ff360000.rkvdec: shared_video_hevc_cabac is not found!
[ 0.340307] rkvdec_init:1257: No hevc cabac reset resource define
[ 0.340330] mpp_rkvdec ff360000.rkvdec: parent devfreq is not ready, retry
[ 0.340618] mpp_rkvdec ff3600b driver failed
[ 0.341804] iommu: Adding device ff351000.av[ 0.341861] mpp_vdpu1 ff351000.avsd_plus: Linked as a consumer to ff350800.iommu
[ 0.342107] mpp_vdpu1 ff351000.avsd_pluse device
[ 0.342551] mpp_vdpu1 ff351000.avsd_plus: reset_gro 0.342583] mpp_vdpu1 ff351000.avsd_plus: reset_group->rw_sem_ mpp_vdpu1 ff351000.avsd_plus: probing finish
[ 0.344040] ioff350400.vdpu: Linked as a consumer to ff350800.iommu
[ 0.34device
[ 0.344694] mpp_vdpu2 ff350400.vdpu: reset_group->rw_ mpp_vdpu2 ff350400.vdpu: reset_group->rw_sem_on=0
[ 0.34507dpu: probing finish
[ 0.345850] iommu: Adding device ff34000 0.345903] mpp_vepu2 ff340000.vepu: Linked as a consumer to ff346155] mpp_vepu2 ff340000.vepu: probe device
[ 0.347022] mpprobing finish
[ 0.348801] mpp_service mpp-srv: probe succes[ 0.354809] dma-pl330 ff1f0000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.354858] dma-pl330 ff1f0000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.356440] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.357795] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.358919] ff120000.serial: ttyS1 at MMIO 0xff120000 (irq = 13, base_baud = 1500000) is a 16550A
[ 0.362902] random: fast init done
[ 0.363434] iommu: Adding device ff370000.vop to group 4
[ 0.363530] rockchip-vop ff370000.vop: Linked as a consumer to ff373f00.iommu
[ 0.363559] random: crng init done
[ 0.368906] rockchip-drm display-subsystem: Linked as a consumer to ff370000.vop
[ 0.370329] rockchip-drm display-subsystem: Linked as a consumer to ff3c0000.hdmi
[ 0.372235] rockchip-drm display-subsystem: devfreq is not set
[ 0.372538] rockchip-vop ff370000.vop: failed to get vop register byname
[ 0.372632] rockchip-vop ff370000.vop: missing rockchip,grf property
[ 0.372849] rockchip-drm display-subsystem: bound ff370000.vop (ops 0xffffff8008fc38b8)
[ 0.372942] ERROR: could not get clock /hdmi@ff3c0000:hclk_vio(3)
[ 0.373314] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
[ 0.374509] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.375748] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops 0xffffff8008fd0078)
[ 0.375781] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.375792] [drm] No driver support for vblank timestamp query.
[ 0.376198] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes
[ 0.376311] rockchip-drm display-subsystem: can't not find any loader display
[ 0.376334] rockchip-drm display-subsystem: failed to show loader logo
[ 0.376389] [drm] Cannot find any crtc or sizes
[ 0.377825] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 0.384941] input: hdmi_cec_key as /devices/platform/ff3c0000.hdmi/dw-hdmi-cec.1.auto/input/input0
[ 0.396142] brd: module loaded
[ 0.412530] loop: module loaded
[ 0.413987] no ATF memory for init
[ 0.419807] rk_gmac-dwmac ff540000.ethernet: PTP uses main clock
[ 0.420037] rk_gmac-dwmac ff540000.ethernet: Linked as a consumer to regulator.3
[ 0.420063] rk_gmac-dwmac ff540000.ethernet: clock input or output? (input).
[ 0.420082] rk_gmac-dwmac ff540000.ethernet: TX delay(0x22).
[ 0.420101] rk_gmac-dwmac ff540000.ethernet: RX delay(0x12).
[ 0.420128] rk_gmac-dwmac ff540000.ethernet: integrated PHY? (no).
[ 0.420214] rk_gmac-dwmac ff540000.ethernet: cannot get clock clk_mac_speed
[ 0.420230] rk_gmac-dwmac ff540000.ethernet: clock input from PHY
[ 0.420502] rk_gmac-dwmac ff540000.ethernet: init for RGMII
[ 0.421056] rk_gmac-dwmac ff540000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[ 0.421090] rk_gmac-dwmac ff540000.ethernet: DWMAC1000
[ 0.421105] rk_gmac-dwmac ff540000.ethernet: DMA HW capability register supported
[ 0.421119] rk_gmac-dwmac ff540000.ethernet: RX Checksum Offload Engine supported
[ 0.421137] rk_gmac-dwmac ff540000.ethernet: COE Type 2
[ 0.421151] rk_gmac-dwmac ff540000.ethernet: TX Checksum ins
[ 0.421171] rk_gmac-dwmac ff540000.ethernet: Wake-Up On Lan 245] rk_gmac-dwmac ff540000.ethernet: Normal descriptors
[ 0c ff540000.ethernet: Ring mode enabled
[ 0.421278] rk_gmac-d: Enable RX Mitigation via HW Watchdog Timer
[ 0.504195] PPP generic driver version 2.4.2
[ 0.504781] usbcore: registered new interface driver asix
[ 0.504891] usbcore: registered new interface driver ax88179_178a
[ 0.504954] usbcore: registered new interface driver cdc_ether
[ 0.505025] usbcore: registered new interface driver rndis_host
[ 0.505091] usbcore: registered new interface driver qmi_wwan
[ 0.507572] dwc3 ff600000.dwc3: Failed to get clk 'ref': -2
[ 0.508515] phy phy-ff470000.usb3-phy.3: u3phy u2 power on
[ 0.508583] phy phy-ff470000.usb3-phy.4: u3phy u3 power on
[ 0.510510] dwc2 ff580000.usb: ff580000.usb supply vusb_d not found, using dummy regulator
[ 0.510719] dwc2 ff580000.usb: Linked as a consumer to regulator.0
[ 0.510749] dwc2 ff580000.usb: ff580000.usb supply vusb_a not found, using dummy regulator
[ 0.641121] dwc2 ff580000.usb: dwc2_check_params: Invalid parameter lpm_clock_gating=1
[ 0.641173] dwc2 ff580000.usb: dwc2_check_params: Invalid parameter besl=1
[ 0.641189] dwc2 ff580000.usb: dwc2_check_params: Invalid parameter hird_threshold_en=1
[ 0.641250] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 0.643253] dwc2 ff580000.usb: DWC OTG Controller
[ 0.643309] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[ 0.643385] dwc2 ff580000.usb: irq 44, io mem 0xff580000
[ 0.643674] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.643696] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.643714] usb usb1: Product: DWC OTG Controller
[ 0.643727] usb usb1: Manufacturer: Linux 4.19.232 dwc2_hsotg
[ 0.643743] usb usb1: SerialNumber: ff580000.usb
[ 0.644868] hub 1-0:1.0: USB hub found
[ 0.644937] hub 1-0:1.0: 1 port detected
[ 0.763439] Freeing initrd memory: 7880K
[ 0.835181] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.835263] ehci-pci: EHCI PCI platform driver
[ 0.835384] ehci-platform: EHCI generic platform driver
[ 0.837889] phy phy-ff450000.syscon:usb2-phy@100.1: charger = USB_CDP_CHARGER
[ 0.838033] ehci-platform ff5c0000.usb: EHCI Host Controller
[ 0.838077] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2
[ 0.839383] ehci-platform ff5c0000.usb: irq 45, io mem 0xff5c0000
[ 0.851024] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[ 0.851482] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.851505] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.851525] usb usb2: Product: EHCI Host Controller
[ 0.851539] usb usb2: Manufacturer: Linux 4.19.232 ehci_hcd
[ 0.851560] usb usb2: SerialNumber: ff5c0000.usb
[ 0.852443] hub 2-0:1.0: USB hub found
[ 0.852508] hub 2-0:1.0: 1 port detected
[ 0.853335] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.853388] ohci-platform: OHCI generic platform driver
[ 0.853963] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[ 0.854007] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3
[ 0.854635] ohci-platform ff5d0000.usb: irq 46, io mem 0xff5d0000
[ 0.915254] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 0.915287] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.915307] usb usb3: Product: Generic Platform OHCI controller
[ 0.915323] usb usb3: Manufacturer: Linux 4.19.232 ohci_hcd
[ 0.915339] usb usb3: SerialNumber: ff5d0000.usb
[ 0.916234] hub 3-0:1.0: USB hub found
[ 0.916298] hub 3-0:1.0: 1 port detected
[ 0.918369] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 0.918421] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 4
[ 0.919706] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x000000b002030010
[ 0.919801] xhci-hcd xhci-hcd.4.auto: irq 58, io mem 0xff600000
[ 0.920452] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.920475] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.920497] usb usb4: Product: xHCI Host Controller
[ 0.920513] usb usb4: Manufacturer: Linux 4.19.232 xhci-hcd
[ 0.920532] usb usb4: SerialNumber: xhci-hcd.4.auto
[ 0.921513] hub 4-0:1.0: USB hub found
[ 0.921584] hub 4-0:1.0: 1 port detected
[ 0.922183] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 0.922225] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 5
[ 0.922261] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[ 0.922389] usb usb5: We don't know the algorithms for LPM for this host, disabling LP] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003, 0.922625] usb usb5: New USB device strings: Mfr=3, Product=2, 0.922647] usb usb5: Product: xHCI Host Controller
[ 0.922662er: Linux 4.19.232 xhci-hcd
[ 0.922683] usb usb5: SerialNumb[ 0.923484] hub 5-0:1.0: USB hub found
[ 0.923543] hub 5-d
[ 0.924472] usbcore: registered new interface driver cdc_aacm: USB Abstract Control Model driver for USB modems and ISDN a88] usbcore: registered new interface driver cdc_wdm
[ 0.925 new interface driver uas
[ 0.925230] usbcore: registered neb-storage
[ 0.925388] usbcore: registered new interface driv
[ 0.925448] usbserial: USB Serial support registered for genbcore: registered new interface driver ch341
[ 0.925571] usbpport registered for ch341-uart
[ 0.925643] usbcore: registever cp210x
[ 0.925684] usbserial: USB Serial support registe 0.925808] usbcore: registered new interface driver ftdi_sio
[ l: USB Serial support registered for FTDI USB Serial Device
[ registered new interface driver option
[ 0.926182] usbserialgistered for GSM modem (1-port)
[ 0.926583] usbcore: registeer pl2303
[ 0.926634] usbserial: USB Serial support register0.926732] usbcore: registered new interface driver qcserial
[ USB Serial support registered for Qualcomm USB modem
[ 0.927ouse device common for all mice
[ 0.928656] <<-GTP-INFO->> G 0.930835] i2c /dev entries driver
[ 0.934912] rk808 1-0018: 0.936070] rk808 1-0018: source: on=0x40, off=0x00
[ 0.942191] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 08-regulator rk808-regulator: there is no dvs1 gpio
[ 0.945320] vdd_logic: supplied by vcc_sys
[ 0.949400] vdd_arm: supplied by vcc_sys
[ 0.951562] vcc_ddr: supplied by vcc_sys
[ 0.954946] vcc_io: supplied by vcc_sys
[ 0.957671] vdd_18: supplied by vcc_io
[ 0.961877] vcc_18emmc: supplied by vcc_io
[ 0.966393] vdd_11: supplied by vcc_io
[ 0.979345] rk808-rtc rk808-rtc: registered as rtc0
[ 0.981132] rk808-rtc rk808-rtc: setting system clock to 2016-01-21 08:50:13 UTC (1453366213)
[ 0.983381] input: rk805 pwrkey as /devices/platform/ff160000.i2c/i2c-1/1-0018/rk805-pwrkey/input/input1
[ 0.984890] IR NEC protocol handler initialized
[ 0.987097] rockchip-iodomain ff100000.syscon:io-domains: Linked as a consumer to regulator.11
[ 0.987174] rockchip-iodomain ff100000.syscon:io-domains: vccio1(3300000 uV) supplied by vcc_io
[ 0.987804] rockchip-iodomain ff100000.syscon:io-domains: Linked as a consumer to regulator.13
[ 0.987844] rockchip-iodomain ff100000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_18emmc
[ 0.988062] rockchip-iodomain ff100000.syscon:io-domains: Dropping the link to regulator.13
[ 0.988175] rockchip-iodomain ff100000.syscon:io-domains: Dropping the link to regulator.11
[ 0.989936] test_power_init: could not find dev node
[ 0.991498] rockchip-thermal ff250000.tsadc: Missing tshut mode property, using default (cru)
[ 0.991528] rockchip-thermal ff250000.tsadc: Missing tshut-polarity property, using default (low)
[ 0.992071] rockchip-thermal ff250000.tsadc: tsadc is probed successfully!
[ 0.994061] device-mapper: uevent: version 1.0.3
[ 0.994748] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[ 0.995038] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[ 0.995402] cpu cpu0: bin=0
[ 0.995476] cpu cpu0: leakage=12
[ 0.995509] cpu cpu0: leakage-volt-sel=1
[ 0.996182] cpu cpu0: Linked as a consumer to regulator.9
[ 0.996286] cpu cpu0: Dropping the link to regulator.9
[ 0.996558] cpu cpu0: Linked as a consumer to regulator.9
[ 0.997852] cpu cpu0: avs=0
[ 0.997915] energy_model: pd0on-monotonically decreasing: em_cap_state 1 >= em_cap_state0
[ : l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table= cpu0: failed to find power_model node
[ 1.000161] sdhci: Seoller Interface driver
[ 1.000176] sdhci: Copyright(c) Pierr88] Synopsys Designware Multimedia Card Interface Driver
[ 1HCI platform and OF driver helper
[ 1.001725] dwmmc_rockchiprmal pinctrl state
[ 1.001730] dwmmc_rockchip ff520000.mmc: te
[ 1.001742] dwmmc_rockchip ff520000.mmc: No idle pinctrl dwmmc_rockchip ff500000.mmc: No idle pinctrl state
[ 1.0019000000.mmc: IDMAC supports 32-bit address mode.
[ 1.001917] d0.mmc: IDMAC supports 32-bit address mode.
[ 1.002638] dwmmc Using internal DMA controller.
[ 1.002669] dwmmc_rockchip f0.mmc: Using internal DMA controller.
[ 1.002682] dwmmc_rock
[ 1.002754] dwmmc_rockchip ff500000.mmc: DW MMC controller ata width,256 deep fifo
[ 1.002810] dwmmc_rockchip ff520000.r at irq 42,32 bit host data width,256 deep fifo
[ 1.002952]is non-removable.
[ 1.003851] ledtrig-cpu: registered to inds
[ 1.004523] hidraw: raw HID events driver (C) Jiri Kosina
registered new interface driver usbhid
[ 1.005098] usbhid:
[ 1.005480] ashmem: initialized
[ 1.008228] rockchip-sarked as a consumer to regulator.12
[ 1.009632] optee: probing DT.
[ 1.009670] optee: revision 1.0
[ 1.009675] optee:
[ 1.014474] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.014918] Initializing XFRM netlink socket
[ 1.014945] IPsec XFRM device driver
[ 1.015664] NET: Registered protocol family 10
[ 1.017034] Segment Routing with IPv6
[ 1.020088] bpfilter: Loaded bpfilter_umh pid 88
Started bpfilter
[ 1.021013] NET: Registered protocol family 17
[ 1.021263] Bluetooth: RFCOMM TTY layer initialized
[ 1.021304] Bluetooth: RFCOMM socket layer initialized
[ 1.021343] Bluetooth: RFCOMM ver 1.11
[ 1.021358] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.021372] Bluetooth: HIDP socket layer initialized
[ 1.021430] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.021437] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.022066] Key type dns_resolver registered
[ 1.023343] registered taskstats version 1
[ 1.023360] Loading compiled-in X.509 certificates
[ 1.023572] Key type ._fscrypt registered
[ 1.023580] Key type .fscrypt registered
[ 1.023586] Key type fscrypt-provisioning registered
[ 1.024991] rga2: Driver loaded successfully ver:4.0.23998
[ 1.025227] rga2: Module initialized.
[ 1.048415] pvtm list NULL
[ 1.048933] vcc_sd: supplied by vcc_io
[ 1.049670] vccio_sd: supplied by vcc_io
[ 1.050278] mpp_rkvdec ff360000.rkvdec: probing start
[ 1.050620] rkvdec_init:1226: failed on clk_get clk_hevc_cabac
[ 1.050695] mpp_rkvdec ff360000.rkvdec: shared_video_hevc_cabac is not found!
[ 1.050701] rkvdec_init:1257: No hevc cabac reset resource define
[ 1.050717] mpp_rkvdec ff360000.rkvdec: parent devfreq is not ready, retry
[ 1.051187] mpp_rkvdec ff360000.rkvdec: probe sub driver failed
[ 1.052329] input: adc-keys as /devices/platform/adc-keys/input/input2
[ 1.053325] rockchip-iodomain ff100000.syscon:io-domains: Linked as a consumer to regulator.11
[ 1.053364] rockchip-iodomain ff100000.syscon:io-domains: vccio1(3300000 uV) supplied by vcc_io
[ 1.053918] rockchip-iodomain ff100000.syscon:io-domains: Linked as a consumer to regulator.13
[ 1.053943] rockchip-iodomain ff100000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_18emmc
[ 1.054014] rockchip-iodomain ff100000.syscon:io-domains: Linked as a consumer to regulator.16
[ 1.054038] rockchip-iodomain ff100000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[ 1.054136] rockchip-iodomain ff100000.sdomains: vccio4(3300000 uV) supplied by vcc_io
[ 1.054204] r100000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_io
chip-iodomain ff100000.syscon:io-domains: Linked as a consumer t 1.054816] rockchip-iodomain ff100000.syscon:io-domains: vccio6(d by vdd_18
[ 1.054918] rockchip-iodomain ff100000.syscon:io00 uV) supplied by vcc_io
[ 1.056422] rockchip-dmc dmc: Linkregulator.8
[ 1.056474] rockchip-dmc dmc: bin=0
[ 1.0565: leakage=12
[ 1.056542] rockchip-dmc dmc: leakage-volt-sel=_rockchip ff500000.mmc: No normal pinctrl state
[ 1.056654] 000.mmc: No idle pinctrl state
[ 1.056803] dwmmc_rockchip ffports 32-bit address mode.
[ 1.057023] rockchip-dmc dmc: avschip-dmc dmc: current ATF version 0x101!
[ 1.057058] rockchiersion 0x101!
[ 1.058807] rockchip-dmc dmc: failed to get vo
[ 1.058818] rockchip-dmc dmc: failed to get vop pn to msch ckchip-dmc dmc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_li 1.059760] dwmmc_rockchip ff500000.mmc: Using internal DMA contrevfreq dmc: Couldn't update frequency transition information.
[rockchip ff500000.mmc: Version ID is 270a
[ 1.060161] dwmmc_ DW MMC controller at irq 41,32 bit host data width,256 deep fifrockchip ff500000.mmc: Linked as a consumer to regulator.15
[ kchip ff500000.mmc: Linked as a consumer to regulator.16
[ 1card hdmi-sound: i2s-hifi <-> ff000000.i2s mapping ok
[ 1.0600.rkvdec: probing start
[ 1.062455] rkvdec_init:1226: failec_cabac
[ 1.062510] mpp_rkvdec ff360000.rkvdec: shared_videound!
[ 1.062516] rkvdec_init:1257: No hevc cabac reset resou62610] mpp_rkvdec ff360000.rkvdec: Linked as a consumer to regul] mpp_rkvdec ff360000.rkvdec: bin=0
[ 1.062658] mpp_rkvdec f=12
[ 1.062669] mpp_rkvdec ff360000.rkvdec: leakage-volt-selp_rkvdec ff360000.rkvdec: avs=0
[ 1.063354] mpp_rkvdec ff360inish
[ 1.064386] input: gpio-keys as /devices/platform/gpio 1.066811] rockchip-pm rockchip-suspend: not set wakeup-config
hip-pm rockchip-suspend: not set pwm-regulator-config
ERROR: andler: unhandled sip (0x4)
[ 1.079695] rockchip-suspend not set sleep-mode-config for mem-lite
[ 1.079703] rockchip-suspend not set wakeup-config for mem-lite
[ 1.079711] rockchip-suspend not set sleep-mode-config for mem-ultra
[ 1.079716] rockchip-suspend not set wakeup-config for mem-ultra
[ 1.07us speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ[ 1.100959] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 1.170475] mmc_host mmc0: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[ 1.254065] usb 2-1: New USB device found, idVendor=0b95, idProduct=1790, bcdDevice= 1.00
[ 1.254090] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.254101] usb 2-1: Product: AX88179
[ 1.254110] usb 2-1: Manufacturer: ASIX Elec. Corp.
[ 1.254120] usb 2-1: SerialNumber: 000000000000F8
[ 1.307690] dwmmc_rockchip ff500000.mmc: Successfully tuned phase to 200
[ 1.307737] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[ 1.309133] mmcblk0: mmc0:aaaa SE32G 29.7 GiB
[ 1.315382] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 1.593173] ax88179_178a 2-1:1.0 eth1: register 'ax88179_178a' at usb-ff5c0000.usb-1, ASIX AX88179 USB 3.0 Gigabit Ethernet, 00:0e:c6:b4:20:87
[ 1.593598] ALSA device list:
[ 1.593620] #0: rockchip,hdmi
[ 1.600195] Freeing unused kernel memory: 6848K
[ 1.600290] Run /init as init process
Loading, please wait...
Starting version 249.11-0ubuntu3.7
[ 2.030564] ax88179_178a 2-1:1.0 enx000ec6b42087: renamed from eth1
[ 2.341600] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
Begin: Will now check userdata file system ... fsck from util-linux 2.37.2
[/usr/sbin/fsck.ext4 (1) -- /dev/mmcblk0p9] fsck.ext4 -a -C0 /dev/mmcblk0p9
userdata: clean, 11/12800 files, 4958/51200 blocks
done.
[ 2.454152] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
Begin: Resizing ext4 file system on /dev/mmcblk0p9 ... [ 2.680979] mmc2: error -110 whilst initialising MMC card
[ 2.707480] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
Model: SD SE32G (sd/mmc)
Disk /dev/mmcblk0: 100%
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 0.03% 0.04% 0.01% uboot
2 0.04% 0.05% 0.01% trust
3 0.05% 0.07% 0.01% misc
4 0.07% 0.08% 0.01% dtbo
5 0.08% 0.13% 0.05% resource
6 0.13% 0.26% 0.13% kernel
7 0.26% 0.42% 0.16% boot
8 0.42% 10.1% 9.67% ext4 rootfs
9 10.1% 100% 89.9% ext4 userdata
resize2fs 1.46.5 (30-Dec-2021)
Resizing the filesystem on /dev/mmcblk0p9 to 7005307 (4k) blocks.
The filesystem on /dev/mmcblk0p9 is now 7005307 (4k) blocks long.
done.
[ 3.431999] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
[ 3.464487] overlayfs: "xino" feature enabled using 32 upper inode bits.
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... done.
[ 3.879991] systemd[1]: System time before build time, advancing clock.
[ 3.962923] systemd[1]: systemd 245.4-4ubuntu3.21 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 3.964994] systemd[1]: Detected architecture arm64.
Welcome to Ubuntu 20.04.6 LTS!
[ 3.994591] systemd[1]: Set hostname to <FriendlyElec>.
[ 4.003732] systemd[1]: Initializing machine ID from random generator.
[ 4.114370] vendor storage:20190527 ret = -1
[ 4.420252] systemd[1]: /etc/systemd/system/rc-local.service:11: Support for option SysVStartPriority= has been removed and it is ignored
[ 4.461501] systemd[1]: Created slice system-modprobe.slice.
[ OK ] Created slice system-modprobe.slice.
[ 4.462833] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 4.463916] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.464401] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password ts to Console Directory Watch.
[ 4.464735] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Ruests to Wall Directory Watch.
[ 4.465890] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ OK ] Set up automount Arbitrarys File System Automount Point.
[ 4.466123] systemd[1]: Reached target Local Encrypted Volumes.
[ OK ] Reached target Local Encrypted Volumes.
[ 4.466315] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Rem.
[ 4.466407] systemd[1]: Reached target Slices.
[ et Slices.
[ 4.466513] systemd[1]: Reached targ ] Reached target Swap.
[ 4.467147] systemdg Socket.
[ OK ] Listening on Syslog Sock] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ening on initctl Compatibility Named Pipe.
[ 4istening on Journal Audit Socket.
[ OK ] Listeningdit Socket.
[ 4.469129] systemd[1]: Listening on Journal[ OK ] Listening on Journal Socket (/dev/l6] systemd[1]: Listening on Journal Socket.
[ OK ]urnal Socket.
[ 4.470435] systemd[1]: Listening on udev 32m OK ] Listening on udev Control Socket.
[1]: Listening on udev Kernel Socket.
[ OK ] Listenrnel Socket.
[ 4.475182] systemd[1]: Mounting Huge Pages Mounting Huge Pages File System...
[ 4.4795ing POSIX Message Queue File System...
Mounting le System...
[ 4.484589] systemd[1]: Mounting Kernel Debug File System...
[ 4.488835] mmc2: error -110 whilst initialising MMC card
[ 4.489974] systemd[1]: Mounting Kernel Trace File System...
[ 4.497136] systemd[1]: Starting Journal Service...
[ 4.502898] systemd[1]: Starting Set the console keyboard layout...
[ 4.508925] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of stodes for the current kernel...
[ 4.514414] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 4.517881] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 4.518289] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 4.526383] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 4.536501] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 4.550824] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 4.551249] systemd[1]: Condition check resulted in Load Kernel Module ramoops being skipped.
[ 4.554708] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 4.562133] systemd[1]: Starting Load Kernel Modules...
[ 4.568154] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.574353] systemd[1]: Starting udev Coldplug all Devices...
[ 4.580792] systemd[1]: Mounted Huge Pages File System.
[ OK ] Mounted Huge Pages File System.
[ 4.582124] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 4.583295] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Debug File System.
[ 4.588139] systemd[1]: Mounted Kernel Trace File System.
[ OK ] Mounted Kernel Trace File System.
[ 4.592222] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ OK ] Finished Create list of st nodes for the current kernel.
[ 4.594773] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[ 4.597109] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[ OK ] Finished Load Kernel Module chromeos_pstore.
[ 4.599612] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[ 4.602227] systemd[1]: Finished Load Kernel Module efi_pstore.
[ OK ] Finished Load Kernel Module efi_pstore.
[ 4.604240] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[ 4.606406] systemd[1]: Finished Load Kernel Module pstore_blk.
[ OK ] Finished Load Kernel Module pstore_blk.
[ 4.608294] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[ 4.610535] systemd[1]: Finished Load Kernel Module pstore_zone.
[ OK ] Finished Load Kernel Module pstore_zone.
[ 4.619787] systemd[1]: Finished Remount Root and Kernel File Systems.
[ OK ] Finished Remount Root and Kernel File Systems.
[ 4.626894] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 4.627116] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 4.631269] systemd[1]: Starting Load/Save Random Seed...
[ 4.636025] systemd[1]: Starting Create System Users...
[ 4.639458] systemd[1]: Finished Load Kernel Modules.
[ OK ] Finished Load Kernel Modules.
[ 4.661503] systemd[1]: Mounting FUSE Control File System...
[ 4.670735] systemd[1]: Mounting Kernel Configuration File System...
[ 4.680386] systemd[1]: Starting Apply Kernel Variables...
[ 4.693625] systemd[1]: Finished Load/Save Random Seed.
[ OK ] Finished Load/Save Random Seed.
[ 4.701042] systemd[1]: Mounted FUSE Control File System.
[ OK ] Mounted FUSE Control File System.
[ 4.706238] systemd[1]: Mounted Kernel Configuration File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Finished Apply Kernel Variables.
[ OK ] Finished Create System Users.
Starting Create Static Device Nodes in /dev...
[ OK ] Finished Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager...
[ OK ] Finished Set the console keyboard layout.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Set console font and keymap...
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage...
[ OK ] Finished Set console font and keymap.
[ OK ] Finished Flush Journal to Persistent Storage.
Starting Create Volatile Files and Directories...
[ OK ] Finished udev Coldplug all Devices.
Starting Helper to synchronize boot up for ifupdown...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Finished Create Volatile Files and Directories.
Starting Network Name Resolution...
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Finished Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Paths.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Started Periodic ext4 Onliata Check for All Filesystems.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily man-db regeneration.
[ OK ] Started Message of the Day.
[ OK ] Reached target Timers.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting LSB: automatic crash report generation...
[ OK ] Started Regular background program processing daemon.
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Save initial kernel messages after boot.
Starting Remove Stale Onlit4 Metadata Check Snapshots...
Starting Init board...
Starting HDMI-force-ON...
Starting Init Onboard LEDs...
Starting Dispatcher daemon for systemd-networkd...
[ OK ] Started Set the CPU Frequency Scaling governor.
Starting System Logging Service...
Starting Login Service...
Starting WPA supplicant...
[ OK ] Finished HDMI-force-ON.
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started System Logging Service.
[ OK ] Started LSB: automatic crash report generation.
[ OK ] Finished Remove Stale Onliext4 Metadata Check Snapshots.
[ OK ] Finished Init Onboard LEDs.
[ OK ] Started WPA supplicant.
[ OK ] Started Login Service.
[ 6.064964] devfreq ff300000.gpu: Couldn't update frequency transition information.
[ OK ] Found device /dev/ttyFIQ0.
Starting Save/Restore Sound Card State...
[ OK ] Finished Save/Restore Sound Card State.
[ OK ] Reached target Sound Card.
[ OK ] Listening on Load/Save RF itch Status /dev/rfkill Watch.
[ OK ] Found device /sys/subsystem/net/devices/eth0.
[ OK ] Started ifup for eth0.
[ OK ] Finished Helper to synchronize boot up for ifupdown.
Starting Raise network interfaces...
[ 6.980960] rk_gmac-dwmac ff540000.ethernet: Failed to reset the dma
[ 6.980985] rk_gmac-dwmac ff540000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 6.980994] rk_gmac-dwmac ff540000.ethernet eth0: stmmac_open: Hw setup failed
[ 6.994346] mmc2: error -110 whilst initialising MMC card
[ OK ] Started Dispatcher daemon for systemd-networkd.
[ OK ] Finished Init board.
[ 9.566573] mmc2: error -110 whilst initialising MMC card
[FAILED] Failed to start Raise network interfaces.
See 'systemctl status networking.service' for details.
[ OK ] Reached target Network.
[ OK ] Reached target Network is Online.
Starting LSB: disk temperature monitoring daemon...
[ OK ] Started lcd2usb.
Starting /etc/rc.local...
Starting OpenBSD Secure Shell server...
Starting Permit User Sessions...
[ OK ] Started /etc/rc.local.
[ OK ] Finished Permit User Sessions.
[ OK ] Started Serial Getty on ttyFIQ0.
Starting Set console scheme...
[ OK ] Started LSB: disk temperature monitoring daemon.
[ OK ] Finished Set console scheme.
[ OK ] Created slice system-getty.slice.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Finished Update UTMP about System Runlevel Changes.
Ubuntu 20.04.6 LTS NanoPi-R2C-Plus ttyFIQ0
NanoPi-R2C-Plus login: I would be grateful if anyone could help me.
