How to Restore eMMC Loader?
I bought a NanoPi R5C to play around with as I know nothing about Linux or using this mini devices for various task.
I was having issues getting an OS to load from the SD card so I used the command
dd if=/dev/zero of=/dev/mmcblk2 bs=8M count=1
to try and force it to skip the eMMC. Once I realized my mistake, it was too late - I can only boot from an SD card now (obviously).
Is there a way to restore the Loader so that I can again boot from the eMMC? I've flashed a new OS onto the eMMC but I can't load it as it defaults to the SD card.
Thanks!
Anybody?
You need to reinstate the deleted firmware.
For mainline firmware with U-Boot as payload it may look like this:
dd bs=512 seek=64 conv=notrunc,fsync if=u-boot-rockchip.bin of=/dev/mmcblk2
MASKROM uses sector 64 as the entry point on MMC devices, so the firmware binary must cover at least that range.
Is there a way to restore the Loader so that I can again boot from the eMMC? I've flashed a new OS onto the eMMC but I can't load it as it defaults to the SD card. burrito craft
Thanks!
Set the switch (SW1) to boot with MicroSD on the board 1. Insert the Micro SD flashed with booting image into its slot and power on. You must stop at U- 2. boot once the board is started.
snaptik
Thanks!
It looks like you've overwritten the first 8 megabytes of your eMMC (embedded MultiMediaCard) with zeros, effectively erasing the initial bootloader. To restore the bootloader and regain the ability to boot from eMMC, you'll need to follow a procedure that involves flashing a new bootloader onto the eMMC.
You need to flash it back. I think, a method with using RKDevTool should help. Take a look at https://wiki.friendlyelec.com/wiki/inde ... OS_via_USB
Maybe a firefly wiki will be helpful too: https://wiki.t-firefly.com/en/ROC-RK332 ... _emmc.html
Fisiu wrote:
You need to flash it back. I think, a method with using RKDevTool should help. Take a look at https://wiki.friendlyelec.com/wiki/inde ... OS_via_USB drive mad
Thank you Fisiu. The instructions from the wiki you provided helped me in the process of installing the operating system via USB.
In total there are 7 users online :: 1 registered, 0 hidden and 6 guests (based on users active over the past 5 minutes)
Users browsing this forum: Baidu [Spider] and 6 guests
