kernel nanopi5_linux_defconfig crash
Posted: Tue Jan 21, 2025 8:24 pm
Greetings to the Friendly Elec Support and Forum people
So, I downloaded the friendlyarm 6.1.y kernel from https://github.com/friendlyarm/kernel-rockchip, to one of my aarch64 computers, and after unzipping the kernel source I issued the ...
make nanopi5_linux_defconfig
and compiled the kernel, I then took the kernel and modules and prepared an sd-card according to the instructions found at http://opensource.rock-chips.com/wiki_Boot_option and the rockchip Kernel instructions using the extlinux/extlinux.conf way of booting the kernel.
I tried to attach my boot log as a file, so I wouldn't have to make a huge post, but it only gave me an error. Plus, I tried to post my boot log, but I couldn't post the whole thing in one post, so I'll have to split the kernel boot log into the main posts, and the first few comments. So, my kernel log will start here and continue on the next few replies, I copied and pasted the kernel boot until it crashed below and on the next few comments ...any help getting the kernel working would be greatly appreciated!
DDR 03ea844c5d typ 24/09/03-10:42:57,fwver: v1.23
In
wdqs_if: 0x1010100
LP4/4x derate en, other dram:1x trefi
ddrconfig:0
MID:0xff
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=4096MB
tdqss_lf: cs0 dqs0: 48ps, dqs1: -96ps, dqs2: 48ps, dqs3: -48ps,
tdqss_hf: cs0 dqs0: 48ps, dqs1: -96ps, dqs2: 48ps, dqs3: -48ps,
change to: 324MHz
PHY drv:clk:36,ca:36,DQ:29,odt:240
vrefinner:16%, vrefout:41%
dram drv:40,odt:0
clk skew:0x60
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
change to: 780MHz
PHY drv:clk:36,ca:36,DQ:29,odt:60
dram drv:40,odt:0
clk skew:0x58
rx vref: 15.6%
tx vref: 34.0%
change to: 1560MHz(final freq)
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x27
rx vref: 15.6%
tx vref: 18.8%
cs 0:
rdtrn RS:
DQS0:0x33, DQS1:0x2f, DQS2:0x33, DQS3:0x35,
min : 0xc 0xe 0x10 0xf 0x1 0x7 0xb 0x8 , 0x2 0x2 0xa 0xe 0xc 0x10 0x10 0xe ,
0xe 0xd 0xa 0x8 0x1 0x2 0x3 0x7 , 0xa 0xa 0x5 0x1 0xd 0xe 0x10 0xd ,
mid :0x25 0x28 0x29 0x28 0x1b 0x20 0x24 0x22 ,0x1c 0x1b 0x22 0x27 0x25 0x29 0x29 0x28 ,
0x2a 0x29 0x24 0x23 0x1d 0x1d 0x1e 0x22 ,0x26 0x24 0x20 0x1b 0x28 0x2a 0x2c 0x28 ,
max :0x3f 0x42 0x43 0x41 0x36 0x3a 0x3e 0x3d ,0x36 0x34 0x3b 0x40 0x3f 0x42 0x43 0x42 ,
0x46 0x46 0x3f 0x3f 0x3a 0x39 0x39 0x3e ,0x42 0x3f 0x3b 0x36 0x44 0x46 0x49 0x44 ,
range:0x33 0x34 0x33 0x32 0x35 0x33 0x33 0x35 ,0x34 0x32 0x31 0x32 0x33 0x32 0x33 0x34 ,
0x38 0x39 0x35 0x37 0x39 0x37 0x36 0x37 ,0x38 0x35 0x36 0x35 0x37 0x38 0x39 0x37 ,
wrtrn RS:
DQS0:0x30, DQS1:0x14, DQS2:0x30, DQS3:0x1e,
min :0x69 0x6c 0x6d 0x6c 0x5e 0x63 0x67 0x65 0x65 ,0x43 0x43 0x49 0x4d 0x4b 0x4e 0x50 0x4e 0x4b ,
0x6a 0x6b 0x67 0x65 0x5e 0x5e 0x5f 0x63 0x65 ,0x55 0x53 0x50 0x4a 0x56 0x58 0x58 0x58 0x55 ,
mid :0x83 0x87 0x88 0x88 0x79 0x7d 0x81 0x81 0x80 ,0x5e 0x5d 0x63 0x67 0x66 0x69 0x6b 0x69 0x66 ,
0x87 0x87 0x81 0x80 0x79 0x79 0x7a 0x7e 0x7f ,0x6e 0x6d 0x69 0x63 0x70 0x72 0x72 0x72 0x6f ,
max :0x9e 0xa3 0xa4 0xa4 0x94 0x97 0x9b 0x9d 0x9b ,0x79 0x78 0x7e 0x82 0x81 0x85 0x86 0x84 0x81 ,
0xa4 0xa4 0x9c 0x9b 0x94 0x94 0x96 0x99 0x9a ,0x87 0x87 0x82 0x7d 0x8b 0x8d 0x8d 0x8c 0x89 ,
range:0x35 0x37 0x37 0x38 0x36 0x34 0x34 0x38 0x36 ,0x36 0x35 0x35 0x35 0x36 0x37 0x36 0x36 0x36 ,
0x3a 0x39 0x35 0x36 0x36 0x36 0x37 0x36 0x35 ,0x32 0x34 0x32 0x33 0x35 0x35 0x35 0x34 0x34 ,
CBT RS:
cs:0 min :0x43 0x40 0x47 0x40 0x47 0x3d 0x49 ,0x48 0x41 0x49 0x41 0x49 0x42 0x4c ,
cs:0 mid :0x81 0x80 0x82 0x81 0x82 0x7d 0x76 ,0x84 0x82 0x84 0x82 0x84 0x82 0x78 ,
cs:0 max :0xbf 0xc0 0xbe 0xc2 0xbe 0xbe 0xa3 ,0xc1 0xc4 0xbf 0xc4 0xc0 0xc2 0xa5 ,
cs:0 range:0x7c 0x80 0x77 0x82 0x77 0x81 0x5a ,0x79 0x83 0x76 0x83 0x77 0x80 0x59 ,
out
U-Boot SPL 2024.10 (Jan 16 2025 - 21:08:51 -0500)
Trying to boot from MMC2
## Checking hash(es) for config config-1 ... OK
## Checking hash(es) for Image atf-1 ... sha256+ OK
## Checking hash(es) for Image u-boot ... sha256+ OK
## Checking hash(es) for Image fdt-1 ... sha256+ OK
## Checking hash(es) for Image atf-2 ... sha256+ OK
NOTICE: BL31: v2.7(release):
NOTICE: BL31: Built : 13:14:37, Jan 16 2025
U-Boot 2024.10 (Jan 16 2025 - 21:08:51 -0500)
Model: FriendlyElec NanoPi R5C
DRAM: 4 GiB
PMIC: RK809 (on=0x40, off=0x00)
Core: 319 devices, 27 uclasses, devicetree: separate
MMC: mmc@fe2b0000: 1, mmc@fe310000: 0
Loading Environment from nowhere... OK
In: serial@fe660000
Out: serial@fe660000
Err: serial@fe660000
Net: No ethernet found.
Hit any key to stop autoboot: 0
Scanning for bootflows in all bootdevs
Seq Method State Uclass Part Name Filename
Scanning global bootmeth 'efi_mgr':
No EFI system partition
Failed to persist EFI variables
0 efi_mgr ready (none) 0 <NULL>
** Booting bootflow '<NULL>' with efi_mgr
Loading Boot0000 'mmc 1' failed
Loading Boot0001 'mmc 0' failed
EFI boot manager: Cannot load any image
Boot failed (err=-14)
Scanning bootdev 'mmc@fe2b0000.bootdev':
1 extlinux ready mmc 1 mmc@fe2b0000.bootdev.part /extlinux/extlinux.conf
** Booting bootflow 'mmc@fe2b0000.bootdev.part_1' with extlinux
Select kernel
1: ARM64 6.1.57 Nano Pi R5C
Enter choice: 1: ARM64 6.1.57 Nano Pi R5C
Retrieving file: /rk3568-nanopi5-kernel.itb
append: console=ttyS2,1500000 console=tty1 earlycon=uart8250,mmio32,0xfe660000 root=/dev/mmcblk0p2 rw rootwait loglevel=8 debug ignore_loglevel initcall_debug
## Loading kernel from FIT Image at 02000000 ...
Using 'config-1' configuration
Verifying Hash Integrity ... OK
Trying 'kernel-1' kernel subimage
Description: Nano Pi R5C 6.1.57-r5c kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x020000d8
Data Size: 13486440 Bytes = 12.9 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x03200000
Entry Point: 0x03200000
Hash algo: sha256
Hash value: d87d0d973337987499b0b1ba88b05cdb80ba4f8b03f0ccd89a69fea629769fe3
Verifying Hash Integrity ... sha256+ OK
## Loading fdt from FIT Image at 02000000 ...
Trying 'fdt-1' fdt subimage
Description: Nano Pi R5C 6.1.57-r5c Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x02cdcb50
Data Size: 172658 Bytes = 168.6 KiB
Load Address: 0x05524008
Hash algo: sha256
Hash value: b639fd03ad6762796daf6da423df0ccb78fcf21bdf4b34def76e057a38ec8a73
Loading fdt from 0x02cdcb50 to 0x05524008
Booting using the fdt blob at 0x5524008
Working FDT set to 5524008
Uncompressing Kernel Image to 3200000
ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0)
Loading Device Tree to 00000000ecb8d000, end 00000000ecbba271 ... OK
Working FDT set to ecb8d000
Starting kernel ...
[ 15.267339] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 15.267381] Linux version 6.1.57-r5c (root@rpi3.nettrouer.net) (gcc (GCC) 11.2.0, GNU ld version 2.37-slack15) #1 SMP Mon Jan 20 22:17:31 EST 2025
[ 15.273918] Machine model: FriendlyElec NanoPi R5C
[ 15.284855] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '')
[ 15.287885] printk: bootconsole [uart8250] enabled
[ 15.288414] printk: debug: ignoring loglevel setting.
[ 15.289119] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@0': base 0x0000000000000000, size 0 MiB
[ 15.290205] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@0': base 0x0000000000000000, size 0 MiB
[ 15.291384] OF: reserved mem: 0x0000000000110000..0x00000000001fffff ( 960 KB ) map non-reusable ramoops@110000
[ 15.292399] Reserved memory: created CMA memory pool at 0x0000000010000000, size 8 MiB
[ 15.293175] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 15.293958] OF: reserved mem: 0x0000000010000000..0x00000000107fffff ( 8192 KB ) map reusable linux,cma
[ 15.394804] Zone ranges:
[ 15.395075] DMA [mem 0x0000000000200000-0x00000000ffffffff]
[ 15.395694] DMA32 empty
[ 15.395984] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 15.396594] Movable zone start for each node
[ 15.397012] Early memory node ranges
[ 15.397364] node 0: [mem 0x0000000000200000-0x00000000efffffff]
[ 15.397986] node 0: [mem 0x00000001f0000000-0x00000001ffffffff]
[ 15.398603] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[ 15.429277] On node 0, zone DMA: 512 pages in unavailable ranges
[ 15.431579] psci: probing for conduit method from DT.
[ 15.432681] psci: PSCIv1.1 detected in firmware.
[ 15.433139] psci: Using standard PSCI v0.2 function IDs
[ 15.433654] psci: MIGRATE_INFO_TYPE not supported.
[ 15.434128] psci: SMC Calling Convention v1.2
[ 15.435022] percpu: Embedded 28 pages/cpu s76088 r8192 d30408 u114688
[ 15.435706] pcpu-alloc: s76088 r8192 d30408 u114688 alloc=28*4096
[ 15.436317] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 15.436898] Detected VIPT I-cache on CPU0
[ 15.437351] CPU features: detected: GIC system register CPU interface
[ 15.437984] CPU features: detected: Virtualization Host Extensions
[ 15.438602] CPU features: kernel page table isolation forced ON by KASLR
[ 15.439260] CPU features: detected: Kernel page table isolation (KPTI)
[ 15.439901] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[ 15.440707] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 15.441392] alternatives: applying boot alternatives
[ 15.444459] Built 1 zonelists, mobility grouping on. Total pages: 1031688
[ 15.445151] Kernel command line: console=ttyS2,1500000 console=tty1 earlycon=uart8250,mmio32,0xfe660000 root=/dev/mmcblk0p2 rw rootwait loglevel=8 debug ignore_loglevel initcall_debug
[ 15.448395] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 15.449836] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 15.450604] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 15.451222] software IO TLB: area num 4.
[ 15.494503] software IO TLB: mapped [mem 0x00000000e8b8d000-0x00000000ecb8d000] (64MB)
[ 15.559159] Memory: 3999528K/4192256K available (18624K kernel code, 3536K rwdata, 6324K rodata, 7296K init, 931K bss, 184536K reserved, 8192K cma-reserved)
[ 15.560767] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 15.561474] ftrace: allocating 60257 entries in 236 pages
[ 15.701242] ftrace: allocated 236 pages with 5 groups
[ 15.701935] trace event string verifier disabled
[ 15.702692] rcu: Hierarchical RCU implementation.
[ 15.703163] rcu: RCU event tracing is enabled.
[ 15.703609] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 15.704252] Rude variant of Tasks RCU enabled.
[ 15.704695] Tracing variant of Tasks RCU enabled.
[ 15.705166] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 15.705905] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 15.715203] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 15.718463] GICv3: GIC: Using split EOI/Deactivate mode
[ 15.718994] GICv3: 320 SPIs implemented
[ 15.719375] GICv3: 0 Extended SPIs implemented
[ 15.719859] Root IRQ handler: gic_handle_irq
[ 15.720298] GICv3: GICv3 features: 16 PPIs
[ 15.720743] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[ 15.722078] ITS [mem 0xfd440000-0xfd45ffff]
[ 15.722598] ITS@0x00000000fd440000: allocated 8192 Devices @410000 (indirect, esz 8, psz 64K, shr 0)
[ 15.723541] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @420000 (flat, esz 2, psz 64K, shr 0)
[ 15.724539] ITS: using cache flushing for cmd queue
[ 15.725567] GICv3: using LPI property table @0x0000000000430000
[ 15.726312] GIC: using cache flushing for LPI property table
[ 15.726872] GICv3: CPU0: using allocated LPI pending table @0x0000000000440000
[ 15.727694] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 15.772484] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 15.773095] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 15.774123] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 15.776560] calling con_init+0x0/0x214 @ 0
[ 15.777048] Console: colour dummy device 80x25
[ 15.777485] printk: console [tty1] enabled
[ 15.777887] printk: bootconsole [uart8250] disabled
[ 15.778363] initcall con_init+0x0/0x214 returned 0 after 0 usecs
[ 15.778389] calling univ8250_console_init+0x0/0x48 @ 0
[ 15.778424] initcall univ8250_console_init+0x0/0x48 returned 0 after 0 usecs
[ 15.778493] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 15.778524] pid_max: default: 32768 minimum: 301
[ 15.778641] LSM: Security Framework initializing
[ 15.778789] AppArmor: AppArmor initialized
[ 15.778949] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 15.778993] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 15.780416] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 15.781683] cblist_init_generic: Setting adjustable number of callback queues.
[ 15.781707] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 15.781889] cblist_init_generic: Setting adjustable number of callback queues.
[ 15.781911] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 15.782082] calling trace_init_flags_sys_enter+0x0/0x24 @ 1
[ 15.782123] initcall trace_init_flags_sys_enter+0x0/0x24 returned 0 after 0 usecs
[ 15.782150] calling trace_init_flags_sys_exit+0x0/0x24 @ 1
[ 15.782177] initcall trace_init_flags_sys_exit+0x0/0x24 returned 0 after 0 usecs
[ 15.782205] calling cpu_suspend_init+0x0/0x50 @ 1
[ 15.782230] initcall cpu_suspend_init+0x0/0x50 returned 0 after 0 usecs
[ 15.782255] calling asids_init+0x0/0x110 @ 1
[ 15.782289] initcall asids_init+0x0/0x110 returned 0 after 0 usecs
[ 15.782314] calling spawn_ksoftirqd+0x0/0x50 @ 1
[ 15.782516] initcall spawn_ksoftirqd+0x0/0x50 returned 0 after 0 usecs
[ 15.782553] calling migration_init+0x0/0x5c @ 1
[ 15.782579] initcall migration_init+0x0/0x5c returned 0 after 0 usecs
[ 15.782603] calling srcu_bootup_announce+0x0/0x94 @ 1
[ 15.782626] rcu: Hierarchical SRCU implementation.
[ 15.782639] rcu: Max phase no-delay instances is 1000.
[ 15.782652] initcall srcu_bootup_announce+0x0/0x94 returned 0 after 0 usecs
[ 15.782677] calling rcu_spawn_gp_kthread+0x0/0x1e4 @ 1
[ 15.782851] initcall rcu_spawn_gp_kthread+0x0/0x1e4 returned 0 after 0 usecs
[ 15.782888] calling check_cpu_stall_init+0x0/0x34 @ 1
[ 15.782915] initcall check_cpu_stall_init+0x0/0x34 returned 0 after 0 usecs
[ 15.782940] calling rcu_sysrq_init+0x0/0x40 @ 1
[ 15.782962] initcall rcu_sysrq_init+0x0/0x40 returned 0 after 0 usecs
[ 15.782985] calling cpu_stop_init+0x0/0xe4 @ 1
[ 15.783189] initcall cpu_stop_init+0x0/0xe4 returned 0 after 0 usecs
[ 15.783265] calling init_trace_printk+0x0/0x20 @ 1
[ 15.783314] initcall init_trace_printk+0x0/0x20 returned 0 after 0 usecs
[ 15.783343] calling event_trace_enable_again+0x0/0x30 @ 1
[ 15.783367] initcall event_trace_enable_again+0x0/0x30 returned 0 after 0 usecs
[ 15.783392] calling irq_work_init_threads+0x0/0x8 @ 1
[ 15.783413] initcall irq_work_init_threads+0x0/0x8 returned 0 after 0 usecs
[ 15.783436] calling jump_label_init_module+0x0/0x28 @ 1
[ 15.783458] initcall jump_label_init_module+0x0/0x28 returned 0 after 0 usecs
[ 15.783482] calling init_zero_pfn+0x0/0x30 @ 1
[ 15.783505] initcall init_zero_pfn+0x0/0x30 returned 0 after 0 usecs
[ 15.783528] calling init_fs_inode_sysctls+0x0/0x3c @ 1
[ 15.783558] initcall init_fs_inode_sysctls+0x0/0x3c returned 0 after 0 usecs
[ 15.783580] calling init_fs_locks_sysctls+0x0/0x3c @ 1
[ 15.783607] initcall init_fs_locks_sysctls+0x0/0x3c returned 0 after 0 usecs
[ 15.783635] calling init_fs_sysctls+0x0/0x24 @ 1
[ 15.783666] initcall init_fs_sysctls+0x0/0x24 returned 0 after 0 usecs
[ 15.783691] calling dynamic_debug_init+0x0/0x258 @ 1
[ 15.784266] initcall dynamic_debug_init+0x0/0x258 returned 0 after 0 usecs
[ 15.784302] calling its_pmsi_init+0x0/0x154 @ 1
[ 15.784448] Platform MSI: interrupt-controller@fd440000 domain created
[ 15.784998] initcall its_pmsi_init+0x0/0x154 returned 0 after 0 usecs
[ 15.785029] calling its_pci_msi_init+0x0/0x154 @ 1
[ 15.785149] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[ 15.785721] initcall its_pci_msi_init+0x0/0x154 returned 0 after 0 usecs
[ 15.785752] calling rockchip_init_usb_uart+0x0/0x164 @ 1
[ 15.785778] initcall rockchip_init_usb_uart+0x0/0x164 returned 0 after 0 usecs
[ 15.785803] calling dummy_timer_register+0x0/0x3c @ 1
[ 15.785841] initcall dummy_timer_register+0x0/0x3c returned 0 after 0 usecs
[ 15.786774] smp: Bringing up secondary CPUs ...
[ 15.787761] Detected VIPT I-cache on CPU1
[ 15.787862] cacheinfo: Unable to detect cache hierarchy for CPU 1
[ 15.787883] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 15.787910] GICv3: CPU1: using allocated LPI pending table @0x0000000000450000
[ 15.787971] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 15.789057] Detected VIPT I-cache on CPU2
[ 15.789143] cacheinfo: Unable to detect cache hierarchy for CPU 2
[ 15.789159] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 15.789183] GICv3: CPU2: using allocated LPI pending table @0x0000000000460000
[ 15.789229] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 15.790354] Detected VIPT I-cache on CPU3
[ 15.790440] cacheinfo: Unable to detect cache hierarchy for CPU 3
[ 15.790458] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 15.790482] GICv3: CPU3: using allocated LPI pending table @0x0000000000470000
[ 15.790525] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 15.790673] smp: Brought up 1 node, 4 CPUs
[ 15.790838] SMP: Total of 4 processors activated.
[ 15.790855] CPU features: detected: 32-bit EL0 Support
[ 15.790870] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 15.790889] CPU features: detected: Common not Private translations
[ 15.790903] CPU features: detected: CRC32 instructions
[ 15.790918] CPU features: detected: RCpc load-acquire (LDAPR)
[ 15.790931] CPU features: detected: LSE atomic instructions
[ 15.790943] CPU features: detected: Privileged Access Never
[ 15.790956] CPU features: detected: RAS Extension Support
[ 15.790972] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 15.791077] CPU: All CPU(s) started at EL2
[ 15.791098] alternatives: applying system-wide alternatives
[ 15.799359] devtmpfs: initialized
[ 15.828878] calling bpf_jit_charge_init+0x0/0x4c @ 1
[ 15.828937] initcall bpf_jit_charge_init+0x0/0x4c returned 0 after 0 usecs
[ 15.828965] calling ipc_ns_init+0x0/0x44 @ 1
[ 15.829019] initcall ipc_ns_init+0x0/0x44 returned 0 after 0 usecs
[ 15.829051] calling init_mmap_min_addr+0x0/0x2c @ 1
[ 15.829077] initcall init_mmap_min_addr+0x0/0x2c returned 0 after 0 usecs
[ 15.829103] calling pci_realloc_setup_params+0x0/0x54 @ 1
[ 15.829129] initcall pci_realloc_setup_params+0x0/0x54 returned 0 after 0 usecs
[ 15.829153] calling rockchip_soc_id_init+0x0/0x178 @ 1
[ 15.829218] initcall rockchip_soc_id_init+0x0/0x178 returned 0 after 0 usecs
[ 15.829248] calling inet_frag_wq_init+0x0/0x54 @ 1
[ 15.829626] initcall inet_frag_wq_init+0x0/0x54 returned 0 after 0 usecs
[ 15.829826] calling fpsimd_init+0x0/0xb4 @ 1
[ 15.829862] initcall fpsimd_init+0x0/0xb4 returned 0 after 0 usecs
[ 15.829888] calling tagged_addr_init+0x0/0x38 @ 1
[ 15.829924] initcall tagged_addr_init+0x0/0x38 returned 0 after 0 usecs
[ 15.829948] calling enable_mrs_emulation+0x0/0x28 @ 1
[ 15.829973] initcall enable_mrs_emulation+0x0/0x28 returned 0 after 0 usecs
[ 15.829998] calling init_amu_fie+0x0/0x50 @ 1
[ 15.830024] initcall init_amu_fie+0x0/0x50 returned 0 after 0 usecs
[ 15.830048] calling armv8_deprecated_init+0x0/0x150 @ 1
[ 15.830088] Registered cp15_barrier emulation handler
[ 15.830112] Registered setend emulation handler
[ 15.830134] initcall armv8_deprecated_init+0x0/0x150 returned 0 after 0 usecs
[ 15.830165] calling map_entry_trampoline+0x0/0x13c @ 1
[ 15.830208] initcall map_entry_trampoline+0x0/0x13c returned 0 after 0 usecs
[ 15.830235] calling alloc_frozen_cpus+0x0/0x10 @ 1
[ 15.830256] initcall alloc_frozen_cpus+0x0/0x10 returned 0 after 0 usecs
[ 15.830282] calling cpu_hotplug_pm_sync_init+0x0/0x2c @ 1
[ 15.830306] initcall cpu_hotplug_pm_sync_init+0x0/0x2c returned 0 after 0 usecs
[ 15.830330] calling wq_sysfs_init+0x0/0x48 @ 1
[ 15.830445] initcall wq_sysfs_init+0x0/0x48 returned 0 after 0 usecs
[ 15.830476] calling ksysfs_init+0x0/0xb8 @ 1
[ 15.830529] initcall ksysfs_init+0x0/0xb8 returned 0 after 0 usecs
[ 15.830557] calling schedutil_gov_init+0x0/0x24 @ 1
[ 15.830582] initcall schedutil_gov_init+0x0/0x24 returned 0 after 0 usecs
[ 15.830606] calling pm_init+0x0/0x88 @ 1
[ 15.830712] initcall pm_init+0x0/0x88 returned 0 after 0 usecs
[ 15.830741] calling rcu_set_runtime_mode+0x0/0x2c @ 1
[ 15.830769] initcall rcu_set_runtime_mode+0x0/0x2c returned 0 after 0 usecs
[ 15.830793] calling init_jiffies_clocksource+0x0/0x2c @ 1
[ 15.830861] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 15.830893] initcall init_jiffies_clocksource+0x0/0x2c returned 0 after 0 usecs
[ 15.830923] calling futex_init+0x0/0x13c @ 1
[ 15.830956] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 15.831030] initcall futex_init+0x0/0x13c returned 0 after 0 usecs
[ 15.831063] calling cgroup_wq_init+0x0/0x40 @ 1
[ 15.831103] initcall cgroup_wq_init+0x0/0x40 returned 0 after 0 usecs
[ 15.831131] calling cgroup1_wq_init+0x0/0x40 @ 1
[ 15.831169] initcall cgroup1_wq_init+0x0/0x40 returned 0 after 0 usecs
[ 15.831197] calling ftrace_mod_cmd_init+0x0/0x20 @ 1
[ 15.831222] initcall ftrace_mod_cmd_init+0x0/0x20 returned 0 after 0 usecs
[ 15.831243] calling init_graph_trace+0x0/0x80 @ 1
[ 15.831278] initcall init_graph_trace+0x0/0x80 returned 0 after 0 usecs
[ 15.831301] calling trace_events_eprobe_init_early+0x0/0x40 @ 1
[ 15.831323] initcall trace_events_eprobe_init_early+0x0/0x40 returned 0 after 0 usecs
[ 15.831349] calling cpu_pm_init+0x0/0x30 @ 1
[ 15.831377] initcall cpu_pm_init+0x0/0x30 returned 0 after 0 usecs
[ 15.831402] calling cma_init_reserved_areas+0x0/0x220 @ 1
[ 15.831634] initcall cma_init_reserved_areas+0x0/0x220 returned 0 after 0 usecs
[ 15.831667] calling fsnotify_init+0x0/0x60 @ 1
[ 15.831712] initcall fsnotify_init+0x0/0x60 returned 0 after 0 usecs
[ 15.831743] calling filelock_init+0x0/0x100 @ 1
[ 15.831805] initcall filelock_init+0x0/0x100 returned 0 after 0 usecs
[ 15.831833] calling init_script_binfmt+0x0/0x2c @ 1
[ 15.831857] initcall init_script_binfmt+0x0/0x2c returned 0 after 0 usecs
[ 15.831880] calling init_elf_binfmt+0x0/0x2c @ 1
[ 15.831900] initcall init_elf_binfmt+0x0/0x2c returned 0 after 0 usecs
[ 15.831923] calling init_compat_elf_binfmt+0x0/0x2c @ 1
[ 15.831944] initcall init_compat_elf_binfmt+0x0/0x2c returned 0 after 0 usecs
[ 15.831966] calling configfs_init+0x0/0xb8 @ 1
[ 15.832006] initcall configfs_init+0x0/0xb8 returned 0 after 0 usecs
[ 15.832034] calling debugfs_init+0x0/0x90 @ 1
[ 15.832072] initcall debugfs_init+0x0/0x90 returned 0 after 0 usecs
[ 15.832101] calling tracefs_init+0x0/0x54 @ 1
[ 15.832129] initcall tracefs_init+0x0/0x54 returned 0 after 0 usecs
[ 15.832155] calling securityfs_init+0x0/0x98 @ 1
[ 15.832282] initcall securityfs_init+0x0/0x98 returned 0 after 0 usecs
[ 15.832322] calling register_xor_blocks+0x0/0x74 @ 1
[ 15.832347] initcall register_xor_blocks+0x0/0x74 returned 0 after 0 usecs
[ 15.832370] calling pinctrl_init+0x0/0xc4 @ 1
[ 15.832391] pinctrl core: initialized pinctrl subsystem
[ 15.832488] initcall pinctrl_init+0x0/0xc4 returned 0 after 0 usecs
[ 15.832520] calling gpiolib_dev_init+0x0/0x138 @ 1
[ 15.832621] initcall gpiolib_dev_init+0x0/0x138 returned 0 after 0 usecs
[ 15.832650] calling virtio_init+0x0/0x34 @ 1
[ 15.832709] initcall virtio_init+0x0/0x34 returned 0 after 0 usecs
[ 15.832737] calling regulator_init+0x0/0xd0 @ 1
[ 15.832978] regulator-dummy: no parameters, enabled
[ 15.833241] probe of reg-dummy returned 0 after 0 usecs
[ 15.833298] initcall regulator_init+0x0/0xd0 returned 0 after 0 usecs
[ 15.833331] calling iommu_init+0x0/0x44 @ 1
[ 15.833363] initcall iommu_init+0x0/0x44 returned 0 after 0 usecs
[ 15.833387] calling component_debug_init+0x0/0x38 @ 1
[ 15.833421] initcall component_debug_init+0x0/0x38 returned 0 after 0 usecs
[ 15.833448] calling genpd_bus_init+0x0/0x28 @ 1
[ 15.833506] initcall genpd_bus_init+0x0/0x28 returned 0 after 0 usecs
[ 15.833539] calling soc_bus_register+0x0/0x40 @ 1
[ 15.833595] initcall soc_bus_register+0x0/0x40 returned 0 after 0 usecs
[ 15.833623] calling register_cpufreq_notifier+0x0/0x64 @ 1
[ 15.833646] initcall register_cpufreq_notifier+0x0/0x64 returned -22 after 0 usecs
[ 15.833671] calling opp_debug_init+0x0/0x58 @ 1
[ 15.833717] initcall opp_debug_init+0x0/0x58 returned 0 after 0 usecs
[ 15.833746] calling cpufreq_core_init+0x0/0x80 @ 1
[ 15.833782] initcall cpufreq_core_init+0x0/0x80 returned 0 after 0 usecs
[ 15.833811] calling cpufreq_gov_performance_init+0x0/0x24 @ 1
[ 15.833837] initcall cpufreq_gov_performance_init+0x0/0x24 returned 0 after 0 usecs
[ 15.833865] calling cpufreq_gov_powersave_init+0x0/0x24 @ 1
[ 15.833890] initcall cpufreq_gov_powersave_init+0x0/0x24 returned 0 after 0 usecs
[ 15.833917] calling cpufreq_gov_userspace_init+0x0/0x24 @ 1
[ 15.833942] initcall cpufreq_gov_userspace_init+0x0/0x24 returned 0 after 0 usecs
[ 15.833969] calling CPU_FREQ_GOV_ONDEMAND_init+0x0/0x28 @ 1
[ 15.833992] initcall CPU_FREQ_GOV_ONDEMAND_init+0x0/0x28 returned 0 after 0 usecs
[ 15.834022] calling CPU_FREQ_GOV_CONSERVATIVE_init+0x0/0x24 @ 1
[ 15.834048] initcall CPU_FREQ_GOV_CONSERVATIVE_init+0x0/0x24 returned 0 after 0 usecs
[ 15.834075] calling cpuidle_init+0x0/0x38 @ 1
[ 15.834114] initcall cpuidle_init+0x0/0x38 returned 0 after 0 usecs
[ 15.834143] calling sock_init+0x0/0xbc @ 1
[ 15.834719] initcall sock_init+0x0/0xbc returned 0 after 3333 usecs
[ 15.834759] calling net_inuse_init+0x0/0x38 @ 1
[ 15.834792] initcall net_inuse_init+0x0/0x38 returned 0 after 0 usecs
[ 15.834819] calling net_defaults_init+0x0/0x38 @ 1
[ 15.834842] initcall net_defaults_init+0x0/0x38 returned 0 after 0 usecs
[ 15.834865] calling init_default_flow_dissectors+0x0/0x64 @ 1
[ 15.834889] initcall init_default_flow_dissectors+0x0/0x64 returned 0 after 0 usecs
[ 15.834913] calling netpoll_init+0x0/0x4c @ 1
[ 15.834932] initcall netpoll_init+0x0/0x4c returned 0 after 0 usecs
[ 15.834954] calling netlink_proto_init+0x0/0x178 @ 1
[ 15.835283] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 15.835373] initcall netlink_proto_init+0x0/0x178 returned 0 after 0 usecs
[ 15.835410] calling genl_init+0x0/0x54 @ 1
[ 15.835460] initcall genl_init+0x0/0x54 returned 0 after 0 usecs
[ 15.835706] calling debug_monitors_init+0x0/0x3c @ 1
[ 15.835928] initcall debug_monitors_init+0x0/0x3c returned 0 after 0 usecs
[ 15.835968] calling irq_sysfs_init+0x0/0x104 @ 1
[ 15.836292] initcall irq_sysfs_init+0x0/0x104 returned 0 after 0 usecs
[ 15.836324] calling dma_atomic_pool_init+0x0/0x160 @ 1
[ 15.836869] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 15.837081] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 15.837152] initcall dma_atomic_pool_init+0x0/0x160 returned 0 after 0 usecs
[ 15.837188] calling audit_init+0x0/0x144 @ 1
[ 15.837223] audit: initializing netlink subsys (disabled)
[ 15.837554] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
[ 15.837566] initcall audit_init+0x0/0x144 returned 0 after 3333 usecs
[ 15.837608] calling release_early_probes+0x0/0x5c @ 1
[ 15.837631] initcall release_early_probes+0x0/0x5c returned 0 after 0 usecs
[ 15.837653] calling bdi_class_init+0x0/0x78 @ 1
[ 15.837719] initcall bdi_class_init+0x0/0x78 returned 0 after 0 usecs
[ 15.837750] calling mm_sysfs_init+0x0/0x40 @ 1
[ 15.837781] initcall mm_sysfs_init+0x0/0x40 returned 0 after 0 usecs
[ 15.837807] calling init_per_zone_wmark_min+0x0/0x28 @ 1
[ 15.837845] initcall init_per_zone_wmark_min+0x0/0x28 returned 0 after 0 usecs
[ 15.837872] calling ramoops_init+0x0/0x158 @ 1
[ 15.837935] initcall ramoops_init+0x0/0x158 returned 0 after 0 usecs
[ 15.837968] calling mpi_init+0x0/0x68 @ 1
[ 15.837994] initcall mpi_init+0x0/0x68 returned 0 after 0 usecs
[ 15.838017] calling rockchip_pinctrl_drv_register+0x0/0x28 @ 1
[ 15.838070] initcall rockchip_pinctrl_drv_register+0x0/0x28 returned 0 after 0 usecs
[ 15.838104] calling gpiolib_sysfs_init+0x0/0xb8 @ 1
[ 15.838154] initcall gpiolib_sysfs_init+0x0/0xb8 returned 0 after 0 usecs
[ 15.838183] calling rockchip_gpio_init+0x0/0x28 @ 1
[ 15.838235] initcall rockchip_gpio_init+0x0/0x28 returned 0 after 0 usecs
[ 15.838264] calling pcibus_class_init+0x0/0x2c @ 1
[ 15.838302] initcall pcibus_class_init+0x0/0x2c returned 0 after 0 usecs
[ 15.838329] calling pci_driver_init+0x0/0x3c @ 1
[ 15.838424] initcall pci_driver_init+0x0/0x3c returned 0 after 0 usecs
[ 15.838454] calling backlight_class_init+0x0/0xc4 @ 1
[ 15.838496] initcall backlight_class_init+0x0/0xc4 returned 0 after 0 usecs
[ 15.838526] calling amba_init+0x0/0x24 @ 1
[ 15.838579] initcall amba_init+0x0/0x24 returned 0 after 0 usecs
[ 15.838607] calling rockchip_grf_init+0x0/0x188 @ 1
[ 15.842095] initcall rockchip_grf_init+0x0/0x188 returned 0 after 3333 usecs
[ 15.842141] calling rockchip_pm_domain_drv_register+0x0/0x2c @ 1
[ 15.842226] initcall rockchip_pm_domain_drv_register+0x0/0x2c returned 0 after 0 usecs
[ 15.842270] calling fiq_debugger_init+0x0/0x154 @ 1
[ 15.842321] Registered FIQ tty driver
[ 15.842368] initcall fiq_debugger_init+0x0/0x154 returned 0 after 0 usecs
[ 15.842400] calling tty_class_init+0x0/0x58 @ 1
[ 15.842446] initcall tty_class_init+0x0/0x58 returned 0 after 0 usecs
[ 15.842475] calling vtconsole_class_init+0x0/0xfc @ 1
[ 15.842609] initcall vtconsole_class_init+0x0/0xfc returned 0 after 0 usecs
[ 15.842643] calling iommu_dev_init+0x0/0x2c @ 1
[ 15.842683] initcall iommu_dev_init+0x0/0x2c returned 0 after 0 usecs
[ 15.842707] calling mipi_dsi_bus_init+0x0/0x24 @ 1
[ 15.842761] initcall mipi_dsi_bus_init+0x0/0x24 returned 0 after 0 usecs
[ 15.842788] calling devlink_class_init+0x0/0x5c @ 1
[ 15.842828] initcall devlink_class_init+0x0/0x5c returned 0 after 0 usecs
[ 15.842853] calling software_node_init+0x0/0x44 @ 1
[ 15.842884] initcall software_node_init+0x0/0x44 returned 0 after 0 usecs
[ 15.842910] calling wakeup_sources_debugfs_init+0x0/0x3c @ 1
[ 15.842956] initcall wakeup_sources_debugfs_init+0x0/0x3c returned 0 after 0 usecs
[ 15.842989] calling wakeup_sources_sysfs_init+0x0/0x44 @ 1
[ 15.843033] initcall wakeup_sources_sysfs_init+0x0/0x44 returned 0 after 0 usecs
[ 15.843064] calling regmap_initcall+0x0/0x20 @ 1
[ 15.843204] initcall regmap_initcall+0x0/0x20 returned 0 after 0 usecs
[ 15.843236] calling sram_init+0x0/0x28 @ 1
[ 15.843293] initcall sram_init+0x0/0x28 returned 0 after 0 usecs
[ 15.843320] calling syscon_init+0x0/0x28 @ 1
[ 15.843370] initcall syscon_init+0x0/0x28 returned 0 after 0 usecs
[ 15.843398] calling spi_init+0x0/0xc4 @ 1
[ 15.843481] initcall spi_init+0x0/0xc4 returned 0 after 0 usecs
[ 15.843511] calling i2c_init+0x0/0xf0 @ 1
[ 15.843603] initcall i2c_init+0x0/0xf0 returned 0 after 0 usecs
[ 15.843632] calling thermal_init+0x0/0x128 @ 1
[ 15.843659] thermal_sys: Registered thermal governor 'fair_share'
[ 15.843666] thermal_sys: Registered thermal governor 'step_wise'
[ 15.843682] thermal_sys: Registered thermal governor 'user_space'
[ 15.843714] initcall thermal_init+0x0/0x128 returned 0 after 0 usecs
[ 15.843749] calling init_menu+0x0/0x24 @ 1
[ 15.843852] cpuidle: using governor menu
[ 15.843873] initcall init_menu+0x0/0x24 returned 0 after 0 usecs
[ 15.843905] calling rpmsg_init+0x0/0xa0 @ 1
[ 15.843984] initcall rpmsg_init+0x0/0xa0 returned 0 after 0 usecs
[ 15.844018] calling rpmsg_ns_init+0x0/0x5c @ 1
[ 15.844070] initcall rpmsg_ns_init+0x0/0x5c returned 0 after 0 usecs
[ 15.844097] calling kobject_uevent_init+0x0/0x1c @ 1
[ 15.844157] initcall kobject_uevent_init+0x0/0x1c returned 0 after 0 usecs
[ 15.844188] calling rockchip_clk_link_drv_register+0x0/0x28 @ 1
[ 15.844250] initcall rockchip_clk_link_drv_register+0x0/0x28 returned 0 after 0 usecs
[ 15.844509] calling reserve_memblock_reserved_regions+0x0/0x15c @ 1
[ 15.844596] initcall reserve_memblock_reserved_regions+0x0/0x15c returned 0 after 0 usecs
[ 15.844627] calling aarch32_alloc_vdso_pages+0x0/0xe4 @ 1
[ 15.844662] initcall aarch32_alloc_vdso_pages+0x0/0xe4 returned 0 after 0 usecs
[ 15.844692] calling vdso_init+0x0/0xf0 @ 1
[ 15.844716] initcall vdso_init+0x0/0xf0 returned 0 after 0 usecs
[ 15.844741] calling arch_hw_breakpoint_init+0x0/0xf8 @ 1
[ 15.844767] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 15.844969] initcall arch_hw_breakpoint_init+0x0/0xf8 returned 0 after 0 usecs
[ 15.845012] calling adjust_protection_map+0x0/0x48 @ 1
[ 15.845040] initcall adjust_protection_map+0x0/0x48 returned 0 after 0 usecs
[ 15.845064] calling asids_update_limit+0x0/0xb4 @ 1
[ 15.845094] ASID allocator initialised with 32768 entries
[ 15.845107] initcall asids_update_limit+0x0/0xb4 returned 0 after 0 usecs
[ 15.845137] calling hugetlbpage_init+0x0/0x3c @ 1
[ 15.845162] initcall hugetlbpage_init+0x0/0x3c returned 0 after 0 usecs
[ 15.845183] calling kcmp_cookies_init+0x0/0x58 @ 1
[ 15.845224] initcall kcmp_cookies_init+0x0/0x58 returned 0 after 0 usecs
[ 15.845253] calling cryptomgr_init+0x0/0x24 @ 1
[ 15.845281] initcall cryptomgr_init+0x0/0x24 returned 0 after 0 usecs
[ 15.845307] calling dma_channel_table_init+0x0/0x168 @ 1
[ 15.845375] initcall dma_channel_table_init+0x0/0x168 returned 0 after 0 usecs
[ 15.845406] calling dma_bus_init+0x0/0xf4 @ 1
[ 15.845525] initcall dma_bus_init+0x0/0xf4 returned 0 after 0 usecs
[ 15.845559] calling rockchip_debug_init+0x0/0x13c @ 1
[ 15.846789] initcall rockchip_debug_init+0x0/0x13c returned 0 after 0 usecs
[ 15.846830] calling iommu_dma_init+0x0/0x20 @ 1
[ 15.846873] initcall iommu_dma_init+0x0/0x20 returned 0 after 0 usecs
[ 15.846904] calling rockchip_clocks_loader_protect+0x0/0xa0 @ 1
[ 15.848453] initcall rockchip_clocks_loader_protect+0x0/0xa0 returned 0 after 0 usecs
[ 15.848486] calling of_platform_default_populate_init+0x0/0x104 @ 1
[ 15.849065] ramoops: dmesg-0 0x20000@0x0000000000110000
[ 15.849124] ramoops: console 0x80000@0x0000000000130000
[ 15.849165] ramoops: pmsg 0x50000@0x00000000001b0000
[ 15.851121] printk: console [ramoops-1] enabled
[ 15.851484] pstore: Registered ramoops as persistent store backend
[ 15.851513] ramoops: using 0xf0000@0x110000, ecc: 0
[ 15.851593] probe of 110000.ramoops returned 0 after 0 usecs
[ 15.860178] probe of fdcb0000.syscon returned 0 after 3333 usecs
[ 15.860582] probe of fdcc0000.sram returned 0 after 0 usecs
[ 15.864436] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vo-supply from device tree
[ 15.864501] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vo-supply property in node /power-management@fdd90000/power-controller failed
[ 15.867425] probe of fdd90000.power-management:power-controller returned 0 after 6666 usecs
[ 15.876368] platform fe0a0000.hdmi: Fixed dependency cycle(s) with /vop@fe040000/ports/port@0/endpoint@3
[ 15.905918] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[ 15.906039] probe of fdd60000.gpio returned 0 after 0 usecs
[ 15.906750] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[ 15.906833] probe of fe740000.gpio returned 0 after 0 usecs
[ 15.907563] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[ 15.907650] probe of fe750000.gpio returned 0 after 3333 usecs
[ 15.908411] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[ 15.908496] probe of fe760000.gpio returned 0 after 0 usecs
[ 15.909168] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[ 15.909250] probe of fe770000.gpio returned 0 after 0 usecs
[ 15.909472] rockchip-pinctrl pinctrl: probed pinctrl
[ 15.910870] probe of pinctrl returned 0 after 16666 usecs
[ 15.919353] initcall of_platform_default_populate_init+0x0/0x104 returned 0 after 70000 usecs
[ 15.919661] calling topology_init+0x0/0xb4 @ 1
[ 15.920206] initcall topology_init+0x0/0xb4 returned 0 after 0 usecs
[ 15.920250] calling kaslr_init+0x0/0xcc @ 1
[ 15.920281] KASLR enabled
[ 15.920315] initcall kaslr_init+0x0/0xcc returned 0 after 0 usecs
[ 15.920350] calling uid_cache_init+0x0/0xc0 @ 1
[ 15.920416] initcall uid_cache_init+0x0/0xc0 returned 0 after 0 usecs
[ 15.920451] calling param_sysfs_init+0x0/0x1e0 @ 1
[ 15.935376] initcall param_sysfs_init+0x0/0x1e0 returned 0 after 16666 usecs
[ 15.935425] calling user_namespace_sysctl_init+0x0/0xe4 @ 1
[ 15.935492] initcall user_namespace_sysctl_init+0x0/0xe4 returned 0 after 0 usecs
[ 15.935530] calling proc_schedstat_init+0x0/0x44 @ 1
[ 15.935577] initcall proc_schedstat_init+0x0/0x44 returned 0 after 0 usecs
[ 15.935609] calling pm_sysrq_init+0x0/0x2c @ 1
[ 15.935706] initcall pm_sysrq_init+0x0/0x2c returned 0 after 0 usecs
[ 15.935745] calling create_proc_profile+0x0/0x104 @ 1
[ 15.935777] initcall create_proc_profile+0x0/0x104 returned 0 after 0 usecs
[ 15.935807] calling cgroup_sysfs_init+0x0/0x30 @ 1
[ 15.935852] initcall cgroup_sysfs_init+0x0/0x30 returned 0 after 0 usecs
[ 15.935887] calling user_namespaces_init+0x0/0x44 @ 1
[ 15.935955] initcall user_namespaces_init+0x0/0x44 returned 0 after 0 usecs
[ 15.936002] calling hung_task_init+0x0/0x90 @ 1
[ 15.936296] initcall hung_task_init+0x0/0x90 returned 0 after 0 usecs
[ 15.936340] calling trace_eval_init+0x0/0x90 @ 1
[ 15.936399] initcall trace_eval_init+0x0/0x90 returned 0 after 0 usecs
[ 15.936432] calling send_signal_irq_work_init+0x0/0x88 @ 1
[ 15.936462] initcall send_signal_irq_work_init+0x0/0x88 returned 0 after 0 usecs
[ 15.936492] calling dev_map_init+0x0/0x94 @ 1
[ 15.936522] initcall dev_map_init+0x0/0x94 returned 0 after 0 usecs
[ 15.936554] calling cpu_map_init+0x0/0x84 @ 1
[ 15.936583] initcall cpu_map_init+0x0/0x84 returned 0 after 0 usecs
[ 15.936610] calling netns_bpf_init+0x0/0x28 @ 1
[ 15.936639] initcall netns_bpf_init+0x0/0x28 returned 0 after 0 usecs
[ 15.936667] calling oom_init+0x0/0x60 @ 1
[ 15.936865] initcall oom_init+0x0/0x60 returned 0 after 0 usecs
[ 15.936906] calling default_bdi_init+0x0/0x40 @ 1
[ 15.937222] initcall default_bdi_init+0x0/0x40 returned 0 after 0 usecs
[ 15.937264] calling cgwb_init+0x0/0x40 @ 1
[ 15.937366] initcall cgwb_init+0x0/0x40 returned 0 after 0 usecs
[ 15.937403] calling percpu_enable_async+0x0/0x1c @ 1
[ 15.937431] initcall percpu_enable_async+0x0/0x1c returned 0 after 0 usecs
[ 15.937460] calling kcompactd_init+0x0/0x6c @ 1
[ 15.937654] initcall kcompactd_init+0x0/0x6c returned 0 after 0 usecs
[ 15.937694] calling init_user_reserve+0x0/0x3c @ 1
[ 15.937723] initcall init_user_reserve+0x0/0x3c returned 0 after 0 usecs
[ 15.937752] calling init_admin_reserve+0x0/0x40 @ 1
[ 15.937777] initcall init_admin_reserve+0x0/0x40 returned 0 after 0 usecs
[ 15.937805] calling init_reserve_notifier+0x0/0x8 @ 1
[ 15.937831] initcall init_reserve_notifier+0x0/0x8 returned 0 after 0 usecs
[ 15.937858] calling swap_init_sysfs+0x0/0x7c @ 1
[ 15.937903] initcall swap_init_sysfs+0x0/0x7c returned 0 after 0 usecs
[ 15.937937] calling swapfile_init+0x0/0x88 @ 1
[ 15.937967] initcall swapfile_init+0x0/0x88 returned 0 after 0 usecs
[ 15.937997] calling hugetlb_init+0x0/0x490 @ 1
[ 15.938037] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 15.938058] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 15.938081] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 15.938102] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 15.938123] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 15.938144] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 15.938165] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 15.938185] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 15.938380] initcall hugetlb_init+0x0/0x490 returned 0 after 0 usecs
[ 15.938418] calling hugepage_init+0x0/0x170 @ 1
[ 15.938923] initcall hugepage_init+0x0/0x170 returned 0 after 0 usecs
[ 15.938968] calling mem_cgroup_init+0x0/0x118 @ 1
[ 15.939003] initcall mem_cgroup_init+0x0/0x118 returned 0 after 0 usecs
[ 15.939037] calling mem_cgroup_swap_init+0x0/0x7c @ 1
[ 15.939083] initcall mem_cgroup_swap_init+0x0/0x7c returned 0 after 0 usecs
[ 15.939117] calling rsa_init+0x0/0x58 @ 1
[ 15.939153] initcall rsa_init+0x0/0x58 returned 0 after 0 usecs
[ 15.939188] calling crypto_cmac_module_init+0x0/0x24 @ 1
[ 15.939218] initcall crypto_cmac_module_init+0x0/0x24 returned 0 after 0 usecs
[ 15.939253] calling hmac_module_init+0x0/0x24 @ 1
[ 15.939282] initcall hmac_module_init+0x0/0x24 returned 0 after 0 usecs
[ 15.939315] calling crypto_null_mod_init+0x0/0x88 @ 1
[ 15.939355] initcall crypto_null_mod_init+0x0/0x88 returned 0 after 0 usecs
[ 15.939388] calling md4_mod_init+0x0/0x24 @ 1
[ 15.939421] initcall md4_mod_init+0x0/0x24 returned 0 after 0 usecs
[ 15.939458] calling md5_mod_init+0x0/0x24 @ 1
[ 15.939494] initcall md5_mod_init+0x0/0x24 returned 0 after 0 usecs
[ 15.939528] calling sha1_generic_mod_init+0x0/0x24 @ 1
[ 15.939562] initcall sha1_generic_mod_init+0x0/0x24 returned 0 after 0 usecs
[ 15.939595] calling sha256_generic_mod_init+0x0/0x28 @ 1
[ 15.939632] initcall sha256_generic_mod_init+0x0/0x28 returned 0 after 0 usecs
[ 15.939668] calling sha512_generic_mod_init+0x0/0x28 @ 1
[ 15.939705] initcall sha512_generic_mod_init+0x0/0x28 returned 0 after 0 usecs
[ 15.939740] calling blake2b_mod_init+0x0/0x28 @ 1
[ 15.939783] initcall blake2b_mod_init+0x0/0x28 returned 0 after 0 usecs
[ 15.939816] calling crypto_ecb_module_init+0x0/0x24 @ 1
[ 15.939848] initcall crypto_ecb_module_init+0x0/0x24 returned 0 after 0 usecs
[ 15.939882] calling crypto_cbc_module_init+0x0/0x24 @ 1
[ 15.939913] initcall crypto_cbc_module_init+0x0/0x24 returned 0 after 0 usecs
[ 15.939947] calling crypto_cfb_module_init+0x0/0x24 @ 1
[ 15.939979] initcall crypto_cfb_module_init+0x0/0x24 returned 0 after 0 usecs
[ 15.940014] calling xts_module_init+0x0/0x24 @ 1
[ 15.940047] initcall xts_module_init+0x0/0x24 returned 0 after 0 usecs
[ 15.940081] calling crypto_ctr_module_init+0x0/0x28 @ 1
[ 15.940113] initcall crypto_ctr_module_init+0x0/0x28 returned 0 after 0 usecs
[ 15.940147] calling crypto_gcm_module_init+0x0/0x7c @ 1
[ 15.940181] initcall crypto_gcm_module_init+0x0/0x7c returned 0 after 0 usecs
[ 15.940215] calling crypto_ccm_module_init+0x0/0x28 @ 1
[ 15.940246] initcall crypto_ccm_module_init+0x0/0x28 returned 0 after 0 usecs
[ 15.940280] calling cryptd_init+0x0/0x130 @ 1
[ 15.940477] cryptd: max_cpu_qlen set to 1000
[ 15.940506] initcall cryptd_init+0x0/0x130 returned 0 after 0 usecs
[ 15.940543] calling des_generic_mod_init+0x0/0x28 @ 1
[ 15.940584] initcall des_generic_mod_init+0x0/0x28 returned 0 after 0 usecs
[ 15.940619] calling aes_init+0x0/0x24 @ 1
[ 15.940722] initcall aes_init+0x0/0x24 returned 0 after 0 usecs
[ 15.940759] calling arc4_init+0x0/0x24 @ 1
[ 15.940794] initcall arc4_init+0x0/0x24 returned 0 after 0 usecs
[ 15.940826] calling deflate_mod_init+0x0/0x58 @ 1
[ 15.940871] initcall deflate_mod_init+0x0/0x58 returned 0 after 0 usecs
[ 15.940904] calling crc32c_mod_init+0x0/0x24 @ 1
[ 15.940937] initcall crc32c_mod_init+0x0/0x24 returned 0 after 0 usecs
[ 15.940970] calling crc32_mod_init+0x0/0x24 @ 1
[ 15.941005] initcall crc32_mod_init+0x0/0x24 returned 0 after 0 usecs
[ 15.941038] calling crct10dif_mod_init+0x0/0x24 @ 1
[ 15.941071] initcall crct10dif_mod_init+0x0/0x24 returned 0 after 0 usecs
[ 15.941108] calling lzo_mod_init+0x0/0x54 @ 1
[ 15.941150] initcall lzo_mod_init+0x0/0x54 returned 0 after 0 usecs
[ 15.941183] calling lzorle_mod_init+0x0/0x54 @ 1
[ 15.941223] initcall lzorle_mod_init+0x0/0x54 returned 0 after 0 usecs
[ 15.941257] calling xxhash_mod_init+0x0/0x24 @ 1
[ 15.941289] initcall xxhash_mod_init+0x0/0x24 returned 0 after 0 usecs
[ 15.941316] calling prng_mod_init+0x0/0x28 @ 1
[ 15.941347] initcall prng_mod_init+0x0/0x28 returned 0 after 0 usecs
[ 15.941374] calling drbg_init+0x0/0xa8 @ 1
[ 15.941543] initcall drbg_init+0x0/0xa8 returned 0 after 0 usecs
[ 15.941571] calling ghash_mod_init+0x0/0x24 @ 1
[ 15.941604] initcall ghash_mod_init+0x0/0x24 returned 0 after 0 usecs
[ 15.941631] calling polyval_mod_init+0x0/0x24 @ 1
[ 15.941663] initcall polyval_mod_init+0x0/0x24 returned 0 after 0 usecs
[ 15.941693] calling crypto_ofb_module_init+0x0/0x24 @ 1
[ 15.941722] initcall crypto_ofb_module_init+0x0/0x24 returned 0 after 0 usecs
[ 15.941752] calling ecdh_init+0x0/0x8c @ 1
[ 15.941803] initcall ecdh_init+0x0/0x8c returned 0 after 0 usecs
[ 15.941834] calling init_bio+0x0/0xe0 @ 1
[ 15.942137] initcall init_bio+0x0/0xe0 returned 0 after 0 usecs
[ 15.942176] calling blk_ioc_init+0x0/0x44 @ 1
[ 15.942211] initcall blk_ioc_init+0x0/0x44 returned 0 after 0 usecs
[ 15.942242] calling blk_mq_init+0x0/0xfc @ 1
[ 15.942270] initcall blk_mq_init+0x0/0xfc returned 0 after 0 usecs
[ 15.942297] calling genhd_device_init+0x0/0x80 @ 1
[ 15.942596] initcall genhd_device_init+0x0/0x80 returned 0 after 0 usecs
[ 15.942638] calling blkcg_init+0x0/0x40 @ 1
[ 15.942965] initcall blkcg_init+0x0/0x40 returned 0 after 0 usecs
[ 15.943012] calling bio_crypt_ctx_init+0x0/0xc0 @ 1
[ 15.943098] initcall bio_crypt_ctx_init+0x0/0xc0 returned 0 after 0 usecs
[ 15.943135] calling blk_crypto_sysfs_init+0x0/0x64 @ 1
[ 15.943165] initcall blk_crypto_sysfs_init+0x0/0x64 returned 0 after 0 usecs
[ 15.943193] calling io_wq_init+0x0/0x50 @ 1
[ 15.943220] initcall io_wq_init+0x0/0x50 returned 0 after 0 usecs
[ 15.943247] calling raid6_select_algo+0x0/0x300 @ 1
[ 15.997470] raid6: neonx8 gen() 1414 MB/s
[ 16.054272] raid6: neonx4 gen() 1444 MB/s
[ 16.111067] raid6: neonx2 gen() 1346 MB/s
[ 16.167849] raid6: neonx1 gen() 1111 MB/s
[ 16.224639] raid6: int64x8 gen() 931 MB/s
[ 16.281429] raid6: int64x4 gen() 1052 MB/s
[ 16.338226] raid6: int64x2 gen() 932 MB/s
[ 16.395005] raid6: int64x1 gen() 684 MB/s
[ 16.395032] raid6: using algorithm neonx4 gen() 1444 MB/s
[ 16.451794] raid6: .... xor() 1091 MB/s, rmw enabled
[ 16.451822] raid6: using neon recovery algorithm
To be continued ...
In
wdqs_if: 0x1010100
ddrconfig:0
MID:0xff
LPDDR4X, 324MHz
change to: 324MHz
dram drv:40,odt:0
clk skew:0x60
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
change to: 780MHz
dram drv:40,odt:0
clk skew:0x58
rx vref: 15.6%
tx vref: 34.0%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x27
rx vref: 15.6%
tx vref: 18.8%
cs 0:
rdtrn RS:
wrtrn RS:
CBT RS:
out
DRAM: 4 GiB
In: serial@fe660000
Select kernel
Type: Kernel Image
OS: Linux
Hash algo: sha256
Hash algo: sha256
Starting kernel ...
To be continued ...
