Nanopi R3S stuck on Solid Red Light
Posted: Wed Oct 15, 2025 9:10 pm
Initially had a friendly wrt with docker install and switched to openwrt release below
```openwrt-24.10.2-rockchip-armv8-friendlyarm_nanopi-r3s-squashfs-sysupgrade.img```
When trying to reflash i get Download Boot failed/ Note Please check ddr, please reset the device and retry in the RKDevTool
Logs below
02:14:33 049 RKDevTool v3.3.7.0 start run
02:18:50 612 RKDevTool v3.3.7.0 start run
02:19:27 454 Error:IsDharaImage-->file size is shorter than 0x7800
02:19:27 473 Error:IsDharaImage-->file size is shorter than 0x7800
02:19:27 501 Layer<4-10>:Download Boot Start
02:19:27 680 <LAYER 4-10> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(59394),Sended(0),crc(1cbd),err(31)
02:19:27 681 <LAYER 4-10> ERROR:DownloadBoot-->Boot_VendorRequest471 failed,index(1)
02:19:27 690 Error:Layer<4-10>:Download Boot Fail
02:19:27 701 Layer<4-10>: RunProc is ending, ret=0
02:19:34 927 Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0
02:19:56 967 INFO:RKU_ResetPipe-->DeviceIoControl OK
02:19:56 968 Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0
02:19:56 978 Error:ResetDeviceProc-->RKU_ResetDevice failed,err=-3
02:21:07 044 Error:RKU_Write-->WriteFile failed,bRet=0,err=995,size=31,write=0
02:21:09 054 ERROR:RKU_ResetPipe-->DeviceIoControl failed,err=31
02:21:18 476 Error:RKU_Write-->WriteFile failed,bRet=0,err=995,size=31,write=0
02:21:20 483 ERROR:RKU_ResetPipe-->DeviceIoControl failed,err=31
02:21:37 618 Error:IsDharaImage-->file size is shorter than 0x7800
02:21:37 619 Error:IsDharaImage-->file size is shorter than 0x7800
02:21:37 632 Layer<4-10>:Download Boot Start
02:21:37 690 <LAYER 4-10> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(2050),Sended(0),crc(6dde),err(31)
02:21:37 690 <LAYER 4-10> ERROR:DownloadBoot-->Boot_VendorRequest471 failed,index(0)
02:21:37 700 Error:Layer<4-10>:Download Boot Fail
02:21:37 712 Layer<4-10>: RunProc is ending, ret=0
02:21:48 557 Error:RKU_Write-->WriteFile failed,bRet=0,err=995,size=31,write=0
02:21:50 560 ERROR:RKU_ResetPipe-->DeviceIoControl failed,err=31
02:21:50 560 Error:DownloadGptParameter failed,RKU_ReadFlashInfo err=-3
02:21:52 814 Error:IsDharaImage-->file size is shorter than 0x7800
02:21:52 827 Layer<4-10>:Download Boot Start
02:21:52 889 <LAYER 4-10> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(2050),Sended(0),crc(6dde),err(31)
02:21:52 890 <LAYER 4-10> ERROR:DownloadBoot-->Boot_VendorRequest471 failed,index(0)
02:21:52 900 Error:Layer<4-10>:Download Boot Fail
02:21:52 912 Layer<4-10>: RunProc is ending, ret=0
02:23:08 943 <LAYER 4-10> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(2050),Sended(0),crc(6dde),err(31)
02:23:08 943 <LAYER 4-10> ERROR:DownloadBoot-->Boot_VendorRequest471 failed,index(0)
02:23:12 564 <LAYER 4-10> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(2050),Sended(0),crc(6dde),err(31)
02:23:12 564 <LAYER 4-10> ERROR:DownloadBoot-->Boot_VendorRequest471 failed,index(0)
02:23:13 120 <LAYER 4-10> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(2050),Sended(0),crc(6dde),err(31)
02:23:13 120 <LAYER 4-10> ERROR:DownloadBoot-->Boot_VendorRequest471 failed,index(0)
02:23:13 474 <LAYER 4-10> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(2050),Sended(0),crc(6dde),err(31)
02:23:13 474 <LAYER 4-10> ERROR:DownloadBoot-->Boot_VendorRequest471 failed,index(0)
02:24:08 115 <LAYER 4-10> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(59394),Sended(12288),crc(1cbd),err(0)
02:24:08 115 <LAYER 4-10> ERROR:DownloadBoot-->Boot_VendorRequest471 failed,index(1)
02:27:24 245 Error:IsDharaImage-->file size is shorter than 0x7800
02:27:24 246 Error:IsDharaImage-->file size is shorter than 0x7800
02:27:24 259 Layer<4-10>:Download Boot Start
02:27:25 188 <LAYER 4-10> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(59394),Sended(0),crc(1cbd),err(31)
02:27:25 188 <LAYER 4-10> ERROR:DownloadBoot-->Boot_VendorRequest471 failed,index(1)
02:27:25 199 Error:Layer<4-10>:Download Boot Fail
02:27:25 213 Layer<4-10>: RunProc is ending, ret=0
02:30:41 786 Error:IsDharaImage-->file size is shorter than 0x7800
02:30:41 801 Layer<4-10>:Download Boot Start
02:30:41 876 <LAYER 4-10> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(2050),Sended(0),crc(6dde),err(31)
02:30:41 876 <LAYER 4-10> ERROR:DownloadBoot-->Boot_VendorRequest471 failed,index(0)
02:30:41 887 Error:Layer<4-10>:Download Boot Fail
02:30:41 899 Layer<4-10>: RunProc is ending, ret=0
02:30:48 841 <LAYER 4-10> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(2050),Sended(0),crc(6dde),err(31)
02:30:48 841 <LAYER 4-10> ERROR:DownloadBoot-->Boot_VendorRequest471 failed,index(0)
Logs below
