NanoPi Neo doesn't boot
I've just received a NanoPi Neo board. I downloaded the ubuntu w/ qte image (http://www.mediafire.com/file/ioa2b3c97 ... 17.img.zip) and burned a Kingstone 8GB class 10 micro sd card.
Then I powered the board with a 5V 2A power supply plugged into the microusb connector.
Leds on ethernet connector light up, the power led is barely on and nothing else happen. I tried to changed the sd-card with no luck.
Am I missing something?
Mark81 wrote:
I've just received a 'NanoPi Neo' board.
image s5p4418-ubuntu-core-qte-sd8g-20171017.img.zip and burned a Kingstone 8GB class 10 micro sd card.
Yes :) your are downloaded a image for another cpu "s5p4418"
For the NanoPi Neo (not 2 nor 2 plus nor NanoPi2 /NanoPi 2 Fire /NanoPi S2 /NanoPi M2A)
= http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO
use a image from the NanoPi Neo directory:
https://www.mediafire.com/folder/n5o8ih ... hdtp5nkect
4418 (Samsung S5P4418) is for the
NanoPi2 /NanoPi 2 Fire /NanoPi S2 /NanoPi M2A Hardware
