Hi all,
I was trying to setup a NanoPi Neo Air for console access over bluetooth - to avoid the need to plug in all the time the cable, following the suggestions in this post.
Instead of using the script I have updated the config files directly as follows:
the /lib/systemd/system/bluetooth.service I have updated as follows:
I have created the file /etc/systemd/system/rfcomm.service with the following content:
I have activated the service with:
After restating the board if I run systemctl I can see the services active:
Now on my mac I go to bluetooth icon and I can see the device being advertised. But if I click on Connect after a short brief "Connected" moment the system moves to "Connection failed".
Has anybody tried to use the bluetooth serial as a console? Or does anybody have any ideas how I can find what the problem is? I've been trying in vain to find a log.
[Service]
Type=dbus
BusName=org.bluez
ExecStart=/usr/lib/bluetooth/bluetoothd -C
ExecStartPost=/usr/bin/sdptool add SP
ExecStartPost=/bin/hciconfig hci0 piscan
NotifyAccess=mainI have created the file /etc/systemd/system/rfcomm.service with the following content:
[Unit]
Description=RFCOMM service
After=bluetooth.service
Requires=bluetooth.service
[Service]
ExecStart=/usr/bin/rfcomm watch hci0 1 getty rfcomm0 115200 vt100 -a pi
[Install]
WantedBy=multi-user.targetI have activated the service with:
sudo systemctl enable rfcomm
sudo systemctl restart rfcommAfter restating the board if I run systemctl I can see the services active:
bluetooth.service loaded active running Bluetooth service
rfcomm.service loaded active running RFCOMM serviceNow on my mac I go to bluetooth icon and I can see the device being advertised. But if I click on Connect after a short brief "Connected" moment the system moves to "Connection failed".
