ubuntu for M1
whats the password?
I used fa as a login password for user fa
but I can't do any kind of sudo operation as it refuses to accept it giving
fa is not in the sudoers file. This incident will be reported
it does however work if you login as root with password fa
I should also note, that its not possible to update/upgrade, as the repo ip's are not found, I assume it needs no repos set up.
This is usually a sign that something is wrong with your network. You don't have IP address or failed DNS server detection/setup.
network is fine, checked connection was ok from other devices, maybe the board was not connecting properly I'll look again.
In total there are 24 users online :: 0 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 24 guests
