RPi.GPIO_NP add_event_detect() broken
i just tried the python library RPi.GPIO_NP.
Adressing the PINs is working:
while True:
    print("12: {}".format(GPIO.input(12)))
    print("22: {}".format(GPIO.input(22)))
    time.sleep(1)
But getting the interrups, always registering pin number 11 (Linux GPIO 0), instead of given pin number:
GPIO.add_event_detect(12, GPIO.BOTH, callback=measure, bouncetime=200)
GPIO.add_event_detect(22, GPIO.FALLING, callback = isr, bouncetime = 200)
- Event detection is then only working, if i connect my button to pin 11.
- Both callbacks are then triggered on pin 11.
root@neo2:~# ls /sys/class/gpio/
export  gpio0  gpiochip0  gpiochip352  unexport
shows that gpio0 is exported
I think it is an issue in the RPi.GPIO_NP library. Can you fix it?
Birdie
What nanopi image or RPi.GPIO_NP library are you using ?
add_event_detect() is not implemented on provided RPi.GPIO_NP by friendlyarm images. There are numerous posts in this forum about this issue.
For info, you may want to build RPi.GPIO_NP from this repo https://github.com/auto3000/RPi.GPIO_NP.
Good luck.
