Can Android be installed on " nanopi fire 2 " ?
I tried to install Android using the " http://wiki.friendlyarm.com/wiki/index. ... oPi_Fire2A " site as a reference.
Try the following conditions.
1. "s5p4418-android-lollipop-20180416.img"
2. SD 16GB, 5V 2A DC
Result : Boot logo infinitely repeated.
question
- > Android Installation Is Available
- > If so, is there any other option not mentioned in wiki?
It's marked as TODO so not likely to have been completed and tested.
antopark93 wrote:
question
seems to be OK from your side.....
You could try to write the image with "etcher" to the uSD Card....
Has the uSD Card tested to be OK?
