[Uboot] fastboot tool flash u-boot source branch is FAILED
Moderator: FATechsupport
I folow the step by step: http://wiki.friendlyarm.com/wiki/index.php/NanoPC-T3#Compile_U-Boot_2
git clone https://github.com/friendlyarm/u-boot.git
cd u-boot
git checkout nanopi2-v2016.01
make make s5p6818_nanopi3_defconfig
make CROSS_COMPILE=aarch64-linux-
Using fastboot tool to flash u-boot.bin faled.
Seeing the log error:
$ ~/nanopc/u-boot
└> sudo fastboot flash bootloader u-boot.bin
sending 'bootloader' (462 KB)...
OKAY [  0.327s]
writing 'bootloader'...
FAILED (remote:  partition does not exist)
finished. total time: 0.338s
NOtes: --Also to try the source from: [url]git clone https://github.com/friendlyarm/uboot_nanopi2.git[/url] compile to flash is success. What is the change?
Did you ever get this to work?
I have the same issue about the size of the file. It is 462K
I am going to try that alternative u-boot repository you mentioned and see what size the file is when built.
I have it working now. You need to use the uboot source at the link you mention.
The other one requires a 64 bit build and suspect this is for ubuntu booting.
The 32 bit verson installs with fastboot and now I can start to get the code to detect the LCD working.
