NanoPi Neo Air Ethernet
Hi All,
Is there a way to add an Ethernet connection to a Nanopi Neo Air without using a clunky usb?
Alternatively, what usb adapters work best?
https://www.armbian.com/nanopi-neo-air/
and scroll down to the "Tested 3rd party hardware"
You can enable the g_ether gadget to connect to your device (for instance through SSH over USB).
Edit /etc/modules to add the following lines:
dwc2
g_ether
Setup your config in /etc/modprobe.d/g_ether.conf
options g_ether hostaddr=00:11:22:33:44:55
Create the usb interface in /etc/network/interfaces.d/usb0
auto usb0
iface usb0 inet static
     address xxx.xxx.xxx.yyy
     netmask 255.255.255.0
     gateway xxx.xxx.xxx.1
Last but not least, enable your interface in /etc/rc.local
sudo ifconfig usb0 up
sudo ifconfig usb0 xxx.xxx.xxx.yyy
Note that this last part should not be needed but on my side the interface never goes up otherwise..
Although the post was sent long ago, I hope this will help you, or anyone looking for something similar! :)
