Adding LAN port over GPIO
Hi every body, i have 4 pieces of Nanopi 2 but i need ethernet connection to HUB, could i have any solution ? Because this is my first time working with SBC, and i trust nanopi has better perfomance
Hi. Are you sure it's the NanoPi 2 or any other NanoPi Neo2/S2/DUO2/... The NanoPi 2 is old and isn't sold anymore.
Best to use a usb to ethernet adapter with the NanoPi 2. I don't know of the availabillity of drivers for it.
I don't see any ethernet break-out pins on it.
Good luck.
i have enc82j60 adapter for it, but still unuseable. but thank you for your information nico
That’s an interesting idea. Using GPIO to add a LAN port sounds challenging but creative, especially for custom or embedded projects. It would be great to see how performance and stability turn out in real use .
