M2 Upload problem
I've discovered there was a problem with the M2 upload speed, i can go on internet with it but it's slow and sometimes it doesn't work. When i install a server on it, it's impossible to take data but we can easily send data to the M2.
I've finaly found the problem come from my switch "D-link DGS-108"(it works perfectly when the M2 is connected to different routers), maybe because of the Qos ? I used other boards with this router, like differents raspberry pi so i don't understand why only the M2 doesn't work :/
Edit: With a network test, the upload data is around 0 during 90% of the time, it's just at then end it go up to his normal speed. i also can also download few kb from the M2 but it stop after 2/3 sec, and sometimes putty can't do a connection to the board surly for the same reason.
Do you have an explanation and maybe a cheap solution ?
We are not quite sure about the root cause. The Ethernet (hardware) should be fine. Its TX can reach 600Mb/s and its RX can reach 900Mb/s.
We suspect that some system settings may be inappropriate.
Bad new with the new switch Netgear G5205 I've exacly the same problem, the transfer stop after 1 sec it's really slow:
https://photos.google.com/photo/AF1QipP ... 8xeIwg8EJB
https://photos.google.com/photo/AF1QipN ... ia9QJjHdQk
As i said in the email i suspect something with the automatic Qos because with my routers i can do Qos rules and I don't have problem but with the switches where the Qos rules seem to be automatic, it doesn't work :/
Edit: it's exacly the same problem for this man: http://superuser.com/questions/258067/1 ... ediacenter
I didn't find a solution but it seems to be the gigabit "mode" of the M2 the problem, i desactived auto-negotiation, choosed 100Mb/s and it works with the switch with no problem but it's still 100Mb/s and i bought this board specialy for his Gigabit port!
I can stop the auto-negotiation for 100Mb/s but not for 1000Mb/s, the link will break, like if i plug/unplug the ethernet cable.
With Ethtool I've got some information, i need an "expert" for find something anormal:
Ethtool eth0:
Settings for eth0:
   Supported ports: [ TP MII ]
   Supported link modes:   10baseT/Half 10baseT/Full
                           100baseT/Half 100baseT/Full
                           1000baseT/Half 1000baseT/Full
   Supported pause frame use: No
   Supports auto-negotiation: Yes
   Advertised link modes:  1000baseT/Full
   Advertised pause frame use: No
   Advertised auto-negotiation: Yes
   Speed: 1000Mb/s
   Duplex: Full
   Port: MII
   PHYAD: 7
   Transceiver: external
   Auto-negotiation: on
   Supports Wake-on: ug
   Wake-on: d
   Current message level: 0x0000003f (63)
                drv probe link timer ifdown ifup
   Link detected: yes
Ethernet driver settings:
root@NanoPi2:~# sudo ethtool -i eth0
sudo: unable to resolve host NanoPi2
driver: st_gmac
version: March_2013
firmware-version:
bus-info:
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: yes
supports-priv-flags: no
Autonegotiation, Rx and Tx:
root@NanoPi2:~# sudo ethtool -a eth0
Pause parameters for eth0:
Autonegotiate:   on
RX:      off
TX:      off
I think Rx, and Tx should not be off, but i tested with 100Mb/s with autonegotiation off or on and i've found the same result.
Network Statistics:
root@NanoPi2:~# sudo ethtool -S eth0
NIC statistics:
     mmc_tx_octetcount_gb: 206399
     mmc_tx_framecount_gb: 578
     mmc_tx_broadcastframe_g: 52
     mmc_tx_multicastframe_g: 39
     mmc_tx_64_octets_gb: 72
     mmc_tx_65_to_127_octets_gb: 258
     mmc_tx_128_to_255_octets_gb: 102
     mmc_tx_256_to_511_octets_gb: 42
     mmc_tx_512_to_1023_octets_gb: 16
     mmc_tx_1024_to_max_octets_gb: 88
     mmc_tx_unicast_gb: 487
     mmc_tx_multicast_gb: 39
     mmc_tx_broadcast_gb: 52
     mmc_tx_underflow_error: 0
     mmc_tx_singlecol_g: 0
     mmc_tx_multicol_g: 0
     mmc_tx_deferred: 0
     mmc_tx_latecol: 0
     mmc_tx_exesscol: 0
     mmc_tx_carrier_error: 0
     mmc_tx_octetcount_g: 206399
     mmc_tx_framecount_g: 578
     mmc_tx_excessdef: 0
     mmc_tx_pause_frame: 0
     mmc_tx_vlan_frame_g: 0
     mmc_rx_framecount_gb: 2553
     mmc_rx_octetcount_gb: 381656
     mmc_rx_octetcount_g: 381656
     mmc_rx_broadcastframe_g: 1330
     mmc_rx_multicastframe_g: 771
     mmc_rx_crc_errror: 0
     mmc_rx_align_error: 0
     mmc_rx_run_error: 0
     mmc_rx_jabber_error: 0
     mmc_rx_undersize_g: 0
     mmc_rx_oversize_g: 0
     mmc_rx_64_octets_gb: 1661
     mmc_rx_65_to_127_octets_gb: 239
     mmc_rx_128_to_255_octets_gb: 182
     mmc_rx_256_to_511_octets_gb: 221
     mmc_rx_512_to_1023_octets_gb: 250
     mmc_rx_1024_to_max_octets_gb: 0
     mmc_rx_unicast_g: 452
     mmc_rx_length_error: 0
     mmc_rx_autofrangetype: 0
     mmc_rx_pause_frames: 0
     mmc_rx_fifo_overflow: 0
     mmc_rx_vlan_frames_gb: 0
     mmc_rx_watchdog_error: 0
     mmc_rx_ipc_intr_mask: 1073692671
     mmc_rx_ipc_intr: 0
     mmc_rx_ipv4_gd: 1021
     mmc_rx_ipv4_hderr: 0
     mmc_rx_ipv4_nopay: 184
     mmc_rx_ipv4_frag: 0
     mmc_rx_ipv4_udsbl: 0
     mmc_rx_ipv4_gd_octets: 250321
     mmc_rx_ipv4_hderr_octets: 0
     mmc_rx_ipv4_nopay_octets: 8464
     mmc_rx_ipv4_frag_octets: 0
     mmc_rx_ipv4_udsbl_octets: 0
     mmc_rx_ipv6_gd_octets: 16448
     mmc_rx_ipv6_hderr_octets: 0
     mmc_rx_ipv6_nopay_octets: 0
     mmc_rx_ipv6_gd: 53
     mmc_rx_ipv6_hderr: 0
     mmc_rx_ipv6_nopay: 0
     mmc_rx_udp_gd: 793
     mmc_rx_udp_err: 0
     mmc_rx_tcp_gd: 281
     mmc_rx_tcp_err: 0
     mmc_rx_icmp_gd: 0
     mmc_rx_icmp_err: 0
     mmc_rx_udp_gd_octets: 219205
     mmc_rx_udp_err_octets: 0
     mmc_rx_tcp_gd_octets: 25024
     mmc_rx_tcp_err_octets: 0
     mmc_rx_icmp_gd_octets: 0
     mmc_rx_icmp_err_octets: 0
     tx_underflow: 0
     tx_carrier: 0
     tx_losscarrier: 0
     vlan_tag: 0
     tx_deferred: 0
     tx_vlan: 0
     tx_jabber: 0
     tx_frame_flushed: 0
     tx_payload_error: 0
     tx_ip_header_error: 0
     rx_desc: 0
     sa_filter_fail: 0
     overflow_error: 0
     ipc_csum_error: 0
     rx_collision: 0
     rx_crc: 0
     dribbling_bit: 0
     rx_length: 0
     rx_mii: 0
     rx_multicast: 0
     rx_gmac_overflow: 0
     rx_watchdog: 0
     da_rx_filter_fail: 0
     sa_rx_filter_fail: 0
     rx_missed_cntr: 0
     rx_overflow_cntr: 0
     rx_vlan: 0
     tx_undeflow_irq: 0
     tx_process_stopped_irq: 0
     tx_jabber_irq: 0
     rx_overflow_irq: 0
     rx_buf_unav_irq: 0
     rx_process_stopped_irq: 0
     rx_watchdog_irq: 0
     tx_early_irq: 0
     fatal_bus_error_irq: 0
     rx_early_irq: 0
     threshold: 1
     tx_pkt_n: 578
     rx_pkt_n: 2553
     normal_irq_n: 1946
     rx_normal_irq_n: 1935
     napi_poll: 1946
     tx_normal_irq_n: 11
     tx_clean: 2144
     tx_reset_ic_bit: 567
     irq_receive_pmt_irq_n: 0
     mmc_tx_irq_n: 0
     mmc_rx_irq_n: 0
     mmc_rx_csum_offload_irq_n: 0
     irq_tx_path_in_lpi_mode_n: 0
     irq_tx_path_exit_lpi_mode_n: 0
     irq_rx_path_in_lpi_mode_n: 1964
     irq_rx_path_exit_lpi_mode_n: 1963
     phy_eee_wakeup_error_n: 0
     ip_hdr_err: 0
     ip_payload_err: 0
     ip_csum_bypassed: 184
     ipv4_pkt_rcvd: 1205
     ipv6_pkt_rcvd: 53
     rx_msg_type_ext_no_ptp: 1258
     rx_msg_type_sync: 0
     rx_msg_type_follow_up: 0
     rx_msg_type_delay_req: 0
     rx_msg_type_delay_resp: 0
     rx_msg_type_pdelay_req: 0
     rx_msg_type_pdelay_resp: 0
     rx_msg_type_pdelay_follow_up: 0
     ptp_frame_type: 0
     ptp_ver: 0
     timestamp_dropped: 0
     av_pkt_rcvd: 0
     av_tagged_pkt_rcvd: 0
     vlan_tag_priority_val: 0
     l3_filter_match: 0
     l4_filter_match: 0
     l3_l4_filter_no_match: 0
     irq_pcs_ane_n: 0
     irq_pcs_link_n: 0
     irq_rgmii_n: 3
