NanoPC-T4 High Quality Audio
Hello all,
I'm running Android 8. Has anyone achieved high quality audio from this board while using an eDP screen? Or perhaps someone has an idea of how I would do so? I don't think the gpio hifi boards for the pi would work here, unless someone knows otherwise. Any ideas?
Anyone? Surely people aren't actually fully satisfied with 3.5mm audio?
I am using eDP. Would it be possible to replicate the video and audio signal over hdmi, then use an audio extractor to pull audio from the hdmi stream?
Hi there, I asked a similar question and didn't get a reply - I don't think this site is used much
maybe a answer to this question you can find in wiki http://wiki.friendlyarm.com/wiki/index. ... dio_device
I appreciate the suggestion, but this doesn't offer a solution to us wanting to use the port designed into the board for video - this merely gives us a way to redirect audio coupled over the hdmi bus. I posted a question asking if anyone knew if using the eDP port would work with replicating the video signal over hdmi while using an audio extractor, or if there is a way to get higher than 3.5mm jack quality audio while using eDP.
Has anyone experimented with this?
In total there are 44 users online :: 0 registered, 0 hidden and 44 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 44 guests
