veveaucent wrote: Quick question. Can the SATA HAT power the NanoPi M4 or do you need one power supply for the M4 and a seperate one for the SATA HAT?
From WiKi - The output current of the 12V to 5V DC/DC regulator is up to 8A From personal experience - a 12 volt power supply unit with 5 amps is enough with a margin.
If it is even easier to say - you are using ONE POWER SUPPLY FOR 12 Volt and EVERYTHING.
A related question: does anyone know where I can find info about the polarity of the 12V input jack? i.e. positive on the central pin or the outer shield? I wouldn't want to fry the board at the first attempt :/
In total there are 24 users online :: 0 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes) Most users ever online was 5265 on Sun Aug 31, 2025 11:40 pm
Users browsing this forum: No registered users and 24 guests
