Nano Pi Fire 3 fails to boot
I have a NanoPi Fire 3 and using the stock Android image on the MicroSD card, it boots fine but the screen is portrait so want to use the custom Android build that I have for the NanoPC T3 Plus and as the build setup is the same on the Wiki for the NanoPi Fire 3, I assumed it would work. I fused this to the MicroSD card and everything looks similar to the stock image, apart from the fact there will be some additional drivers.
When it boots, I see this in the serial terminal.
BL1 by Nexell V1.0.0-g44b48cd [Built on 2017-08-02 15:58:54]
Memory Initialize (0) Done.
Loading from sdmmc...
 Image Loading Done!
Launch to 0x7FD00800
ERROR:   Failed to load BL33 (-2)
and at this point, it just hangs.
I've not changed the bootloader, just the uImage, and the Android image files.
Fixed. I decided to use the existing image and then copy the new files over and fuse the SD card. Now I can boot my custom Android version.
