Change i2c speed on neo-core from 100KHz to 400KHz
I am using the i2c bus quite extensively and have found that it is running at 100KHz.
I have decompiled the sun8i-h3-nanopi-neo-core.dtb and confirmed that it is set to 100KHz.
The .dts file was modified with a 'clock-frequency' value of <0x61a80> (400000 decimal) and recompiled.
After reboot, the logic analyser is showing that it is still only running at 100KHz. :(
This is the modified section of the dts.
The original value for 'clock-frequency' was <186a0>
                i2c@01f02400 {
                        compatible = "allwinner,sun6i-a31-i2c";
                        reg = <0x1f02400 0x400>;
                        interrupts = <0x0 0x2c 0x4>;
                        pinctrl-names = "default";
                        pinctrl-0 = <0x32>;
                        clocks = <0x30 0x9>;
                        clock-frequency = <0x61a80>;
                        resets = <0x30 0x5>;
                        status = "disabled";
                        #address-cells = <0x1>;
                        #size-cells = <0x0>;
                        linux,phandle = <0x77>;
                        phandle = <0x77>;
It would appear that the value in the dtb is being ignored.
Has anyone out there been able to change the speed successfully on one of these boards?
Any help will be most gratefully received.
Gerry
Nano pi Neo
i2c@1c2ac00 {
reg = <0x1c2ac00 0x400>;
interrupts = <0x0 0x6 0x4>;
clocks = <0x3 0x3b>;
resets = <0x3 0x2e>;
pinctrl-0 = <0x17>;
status = "okay";
clock-frequency = <1700000>;
}; // 1.7 Mhz для MCP23017
Here is more .. https://github.com/AlekseyMamontov/NanoPI-NEO-I2C-
status = "okay"
i2c@1c2ac00 {
pinctrl-0 = <0x17>;
status = "okay";
