Is it possible to disable the blinking blue LED?
Is there a way to disable the blinking blue LED? In the night it is too bright.
Thanks.
There are two "easy" options, but I think you are looking for the third ;-)
1. physically remove the LED (eg. with screwdriver), I did similar with dangerous diode for battery charged RTC module
2. Disable blinking code in firmware and rebuild it
3. find some command/setting that allows to disable/enable blinking
Perhaps somebody from Friendlyarm can help on 3?
Hermann.
Found it out.
To turn the heartbeat off:
echo none > /sys/class/leds/blue_led/trigger
To turn it back on:
echo heartbeat > /sys/class/leds/blue_led/trigger
Thanks for that information!
Doing "cat" of that file seems to give the allowed values, with current value in square brackets:
root@FriendlyARM:/sys/class/leds/blue_led# cat trigger
none mmc0 timer heartbeat backlight [gpio] default-on
none, time, heartbeat and default-on have obvious visible effects.
If you want it crazy you can let blue led on heartbeat and set green led (from "defaut-on") to timer ;-)
Not sure what mmc0, backlight and gpio are good for.
Is there any spec or document where this infomation can be found?
Hermann.
