Why use parts that are impossible to purchase????
I bought an RK3399 SOM kit to try it out with the idea of using the SOM on my carrier board and making the design lower power. as I don't need the HDMI, Ethernet etc. The trouble now is that I can't purchase the necessary SODIMM socket. TE don't have any distributor for this part.
Back on the shelf, it goes. :(
There are other interesting choices, such as (NEO4):
-> The camera module from the CAM1320 breakout is EOL.
-> Why are there GPIO, I2C and SPI buses on NEO4's GPIO1 (40 pin header) that are 3V logic and only 5V and 3V3 supply pins available on the same connector?
wut?
https://eu.mouser.com/Connectors/Memory ... x9Z1yq3857
I should have posted this long before now.
I did find a suitable connector. The issue was that the one specified by FA in the Wiki was a high spec part with heavier gold plating and therefore on special factory order only with a high MOQ. I found one of them in the same product range with gold flashing which will work fine for lower volume designs.
