SPI not working on nanopi-m4 android 8.1?
I'm trying to get spi working on m4/8.1.
I am able to setup the port, but only write one character. After that, all calls to SPI return -1.
I can see the single byte appear on the SPI bus.
At boot the spi device reports errors:
[ 1.015664] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.015683] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.015693] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
int r = HardwareControler.SPItransferOneByte(devFD, (byte)3, 0, 1000000 , 8);
r returns 255 the first time, and then -1 from then after...
Hi, I'm currently working to enable SPI on NanoPi M4 but it is not working...
I have edited main DT to the following one and now /dev/spidev0.0 appears.
Quote
spi@ff1c0000 {
compatible = "rockchip,rk3399-spi\0rockchip,rk3066-spi";
reg = < 0x00 0xff1c0000 0x00 0x1000 >;
clocks = < 0x08 0x47 0x08 0x15b >;
clock-names = "spiclk\0apb_pclk";
interrupts = < 0x00 0x44 0x04 0x00 >;
pinctrl-names = "default";
pinctrl-0 = < 0x4a 0x4b 0x4c 0x4d >;
#address-cells = < 0x01 >;
#size-cells = < 0x00 >;
status = "okay";
phandle = < 0x101 >;
snaptube vidmate
spidev{
compatible = "spidev";
status = "okay";
reg = <0>;
spi-max-frequency = <10000000>;
