Dropbox on Neo2?
Hi Guys,
Someone tried to run dropbox on Neo2 successfully, will appreciate any info on this.
Thanks in advance!
Ilia.
IliaB wrote:
Hi Guys,
Someone tried to run dropbox on Neo2 successfully, will apretiate any info on this.
Thanks in advance!
Ilia.
Perhaps this way https://help.dropbox.com/installs-integ ... ands#build ?
Thanks Igor,
Tried this and many other stuff, nothing helps.
I guess it's impossible.
Best Regards.
Ilia.
IliaB wrote:
Thanks Igor,
Best Regards.
Ilia.
I saw they don't provide packages for ARM but building from sources? That should work ... if your build environment is not crippled and with assumption that their sources are alright. Sometimes adjustments or different compiler is needed, adjusting minor things ... well, you have to ask them/authors/dropbox for assistance. FriendlyARM has nothing to do with this.
Hi Igor,
That's what I did eventually, trying to compile from source, too much errors..
Tried rclone https://rclone.org/ app and it works fine, I probably stick with rclone for a while.
Thanks again.
Ilia.
IliaB wrote:
Hi Igor,
Thanks again.
Ilia.
I see ... Rclone looks like a much better option.
