RPi.GPIO_NP
Hello colleagues!
Help me please to solve problem with access to GPIO from Python3.
I have script gpio-test.py:
import RPi.GPIO as GPIO
import time
led1 = 11
led2 = 13
GPIO.setmode(GPIO.BOARD)
GPIO.setup(led1, GPIO.OUT)
GPIO.setup(led2, GPIO.OUT)
while True:
        GPIO.output(led1, True)
        GPIO.output(led2, True)
        time.sleep(2)
        GPIO.output(led1, False)
        GPIO.output(led2, False)
        time.sleep(2)
It is a standard and simple script.
If I run this like pyton gpio-test.py everything is good. LED's blink every two seconds.
But if I run this like python3 gpio-test.py LED's not blink :-( and I have not any error. So as I right understand the RPi.GPIO is not work under Python3. How I can silve it?
BOARD="NanoPi-NEO-Plus2"
BOARD_NAME="NanoPi-NEO-Plus2"
For python3
git clone https://github.com/Tungsteno74/NPi.GPIO
python3 setup.py install
i
mport NPi.GPIO as GPIO
PIN_NUM = 7
GPIO.setup(PIN_NUM,GPIO.OUT)
GPIO.output(PIN_NUM,True)
sleep(1)
GPIO.output(PIN_NUM,False)
sleep(1)
worked.
