SPI first clock pulse
Good morning all,
I'm trying to comunicate with an SPI device on a NanoPi Neo core 2 (SPI0) but i have some problems.
I can't connect the CS signal and I have a strange first clock pulse so the device receive wrong data
As you can see the
Any comments/ suggestions are welcome
Thanks in advace
bpastore wrote:
Good morning all,
As you can see the
Thanks in advace
AFAIK SPI works as expected. Which kernel you use?
If you don't capture the SPI when your CS is low, you are probably reading other SPI activitiy on the bus.
You need to setup your logic analyser to trigger capture when your CS goes low.
