GPIO1_A3 cannot be exported
I can't get code to export the GPIO1_A3 pin on the T4. GPIO1A1 and GPIO1_A4 exports without any errors. In fact, all of the other GPIO pins on the header can be exported.
I tried from the terminal in kernel space with SU but still doesn't export.
The schematic for the T4 shows that GPIO1_A3 only connects to the GPIO header and searching the kernel finds no other use for GPIO1_A3 (GPIO35)
Just a quick update. I found the following would list what each GPIO was currently being used by:
cat /sys/kernel/debug/gpio
gave this:
 gpio-35  (                    |camsys_gpio         ) out hi
Seems that the camera is using this GPIO which seems a bit strange as that pin is not connected to any of the camera connectors, only to the GPIO header.
Need to dig into the camera source to find where this is.
In total there are 37 users online :: 0 registered, 0 hidden and 37 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 37 guests
