Set-up of NEO Core 2
I am planning to use the nanopi neo core 2 for my application. i was following wiki page instruction to set up the board. but i fail to understand how do i give commands to configure SSH or npi-config access as there is no provision to connect the monitor or keyboard.
Need your help to understand the set up procedure.
Any additional links or articles are there to refer ?
Thanks in advance.
Regards,
Pratik
Best way to start is to connect a usb ttl adapter to uart0 this uart is debug uart so you get full access from there.
Uart0 uses 115200 bps
Inside you can use npi-config for basic settings. Core 2 is also from start open for non root ssh. pi/pi
Inside you can elevate to root with sudo -s
Thanks PeterAx. Will try with UART option.
In total there are 34 users online :: 0 registered, 0 hidden and 34 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 34 guests
