NanoPC-T4 Power supply
I want to know if there is another way to power the Nanopc-t4 besides the 12V input power jack. As far as I know, the 12V power input is the only way but If someone has another idea or way to do power the board, it could be very helpful for me.
Thanks.
I am also getting the same error as you said, i dont know how to fix that like you :((
I have not found a solution to this problem either
Have you found the solution yet? I have also been searching for so long but haven't found the solution that I need
There are no other options. All of the other headers are outputs only. I actually like the 12V option as it avoids issues with voltage drops with a 5V supply, which I've seen a number of times. With the 12V input connection, it works from 9V to 14V without any issues. In fact, the datasheet shows 5.5V to 28V as a valid input range.
https://www.monolithicpower.com/en/docu ... t_id/4030/
