NanoPi NEO Air and Ethernet
Hi.
Can I use the board NanoPi NEO Air with Ethernet?
There is no Ethernet hardware on the NEO PI Air. The reference in the Wiki is likely from a copy and paste.
Wifi only.
maks.dav wrote:
Hi.
Directly not, but ypu can buy a WiFi Bridge (like Vonets) and connect the Air to the WiFi on the WiFi Bridge and on the other side of the bridge is a Ethernet-Connector....
The NEO-Air has two USB ports available through headers (when soldered). They can be used to connect an USB-2 Ethernet adapter. See the pins layout at https://wiki.friendlyarm.com/wiki/index ... _Dimension
I've successfully connected an A1277 Apple USB Ethernet Adapter (05ac:1402). It has a ASIX AX88772 chip which is supported in the standard FriendlyWrt image for the board by the `asix` kernel module. The module is not loaded automatically.
To get it to work on reboot, I created a file in /etc/modules.d:
echo asix > /etc/modules.d/90-asix
The only issue is that the combo NanoPi NEO-air + Ethernet adapter is rather power hungry when routing Wifi traffic to Ethernet. With a 2.5Amp 5v power adapter, the voltage drops to ~4.75v and the Ethernet adapter shut down sometimes. Unplug and re-plug brings it back. I need to test with a more powerful power supply.
Update: I switched to a Realtek RTL8153 Gigabit Ethernet Adapter (0bda:8153) which required no specific configuration to work. The stability issue of the asix driver seems to be unrelated to power consumption, likely an issue with the adapter itself or the `asix` kernel module (and that may be why the module is not loaded automatically).
