(SOLVED) MySQL in docker (NanoPi R4S)
Hi
I've installed without any problem Postgres DB and Home-Assistant. Now I'm trying to install MySQL (for use with WordPress) in a docker for the NanoPi R4S (openWRT). It seems that is not any available image for this processor :(
I've installed mysql/mysql-server but it doesn't accept any connection from any docker or to Admin from an external client :(
Help me, thank you.
It's not possible to install MySQL in a docker for this processor ... and it's not correct the Portainer template.
MariaDB is working fine with Wordpress in this device ;-)
There is Armbian https://www.armbian.com/nanopi-r4s/ so it is possible.
Thank you for the info :D
Would it be possible using Armbian to connect it using VNC to have a GUI accessing from an external computer?
Armbian is improved Debian or Ubuntu with improved mainline kernel specialised / focused to ARM single board computers - your by far best chance for getting things done.
https://docs.armbian.com/#what-is-armbian
Any question you have, it might already be answered https://www.armbian.com/search
Is it without bugs? No. Ubuntu is full of them, Debian has it even more ... but its compatible on userland level so instructions applies and applications works.
