NanoPi NEO uart1(ttyS1) enable
Hello!
I'm using NanoPi NEO and FRIENDLYWRT. I found that is not possible to send data via ttyS1, I think that UART1 is disabled in the kernel. How do I create an OpenWRT with UART1 enabled ?
I inserted a line to the target / linux / rockchip / patches-5.4 / 001-rockchip-rk3328-Add-support-for-FriendlyARM-NanoPi-R.patch file that reads: soccer random
"Okay" is the state of the UART1; +;
UART1 is operational at the moment.
qqq558877 wrote:
Hello!
I'm using NanoPi NEO and FRIENDLYWRT. I found that is not possible to send data via ttyS1 planet clicker, I think that UART1 is disabled in the kernel. How do I create an OpenWRT with UART1 enabled ?
To enable UART1 (ttyS1) in OpenWRT (FriendlyWRT) for your NanoPi NEO, you will need to modify the kernel configuration and rebuild OpenWRT with UART1 enabled.
Navigate to the OpenWRT source directory and run the following command to configure the kernel:
make menuconfig
In the menu, navigate to:
Target System → (your NanoPi NEO model)
Target Profile → (specific NanoPi NEO version)
Kernel Modules → (Look for the serial driver settings)
qqq558877 wrote:
Hello!
I'm using NanoPi NEO and FRIENDLYWRT. I found that is not possible to send data via ttyS1, I think that UART1 is disabled in the kernel. How do I create an OpenWRT with UART1 enabled ?drive mad
You need to enable the UART driver in the OpenWRT kernel configuration. You can do this by navigating to the OpenWRT build directory and running make menuconfig. Look for the serial drivers section and ensure that the UART1 driver is selected.
